Constructie Amplificator QUAD 405 - clona
Mircea Radulescu
Desi au trecut ceva ani pana am testat o clona Quad405 luata de pe net si acolo prefinalii erau montati pe radiatorul finalilor. Ma refer la kitul asta:
https://www.ebay.com/itm/QUAD405-CLONE-HiFi-Stereo-Power-Amplifier-2-0-Channel-w-aluminum-angle-MJ15024/113104288954?epid=27020827772&_trkparms=ispr%3D1&hash=item1a558a7cba:g:YYUAAOSw9H5bMfUU&enc=AQAEAAACYIQvEcHUrT7nmUC3yY5qbPyaBN1nJEDYW8MyypsJPgXK0uRDA0YMQdidFRq0W%2F%2FEY%2BqYQO9DZnnO1BhINVxiXh2un7hluihB24ZuHs0IfNCBud3yg7sY3YtLJsS2iuWtWWcpG%2FAWgoQj%2BEjxkkrL5VJxaRtOTQhZ1OE3MuSi1Rc0e3G6oXKQLod8RB%2B1nzciDmcrbVrDAFj9hQMBU2TpGSddn2GhCaFQHDoH3MJfc4ZSh7Okrg0CxfCBmnSHKXjBnWVHf3ZwY6vpGlPg20wCr40ohOxd%2F0unltbHvJ3xzDMAFRFV%2FeUgHUho69Ljw95Ob1XOkldXekViax1XYo5qWtjEYlceKlVsm%2BTtkQjZZNypO5LFlhcdEcWnxk0lkPJLed%2FZQR9DiJj%2BJ4KqZ4KeRWZGmZGDa8aAC%2FbbzU0ZsLDbUjwbSe86BT9xmmJPD1W199RNssHBxrFpzHevHtTRycsyWTbQVEz3spTKyOCwCtErq7OJK0nq4nhU1tX1%2FWTuznGabd3QNiO%2BGdpwgSgEEFx%2B2eIuIYln1TvcOuVbkBX4gvF4vt9EiMMntRJPdcYcHg16nMj3VQqebzqtDTLdLGhSy7N7RgtoRoZM1whZfr6uUqCRn2%2BRdg4M1EzFkzuUqBORV2fAVfZKnkSupxjoRM0mGZEYHrDXaYYWigbjmlwJWOXeNfYMTIq%2BQl4SkIl6szJKI5xqCr0scxtjXNnh%2BNp3R6Wz1Hx8UMNZvb4wLps8ro8C0UQmPDW6KUGnPthrQf%2FRD4OnbzY1j7MoKx%2B686oP%2BqJ8hn75zOygoh5Wpg5D&checksum=1131042889544b7018e635b842a692e996a89a88acdf
Eu din ce am citit la vremea respectiva amplificatorul Quad405 este proiectat sa mearga cu prefinali destul de calduti, presupun, ca sa se obtina si un sunet aparte, tipic Quad405. Adica, nu am calculat, dar banui ca prefinali merg pur in clasa A.
Acum 10 ore, vijelie02 a spus:
Cum ati reusit sa va dati seama domnule @gsabac ca nu oscileaza doar din poza de mai sus? Asta poate spune doar domnul Mircea.
Poate chiar o oscilatie produce acea incalzire excesiva a prefinalilor sau finalilor(ceea ce nu e cazul aici)
La 85-120 grade pe radiatorul ala mic dupa cateva minute de functionare e in lumea celor drepti(prefinalul). Solutia la aceasta problema a dat-o @leo_electro
Ceva masuratori cu un osciloscop in diverse situatii ar fi utile.
Realizarea este excepţională, mai ales ca este trecută prin firul gândirii proprii a userului @Mircea Radulescu.
Raspunsuri la intrebarile dvs. apreciate de @leo_electro sunt:
Din calitatea sunetului şi din curentul mic prin tranzistorii finali, nu se suprancălzesc caci altfel ne spunea autorul.
Pardon de "cateva minute de functionare e in lumea celor drepti(prefinalul)", chestia cu rezistenţa termică jonctiune-capsula (0,5 grade/W)
  si capsula-radiator circa 0,5 grade/W) ne spune automat ca jonctiunea se incalzeste la acest radiator mic doar cu cateva grade mai mult,
  adica mai putin de 5 grade, deci are 125 de grade, aceasta este tendinta moderna de realizare a aparaturilor electronice, mic si fierbinte.
Inca odata felicitari pentru autor si ii urez succes la modernizarea produsului experimental, dupa cel de proba.
  • Sad 1
Doar atat pot spune la adresa d-voastra domnule @gsabac : de putina vreme ati devenit mult prea ursuz. Scot din definitie termenul necomunicativ. Asta se observa si pe forumul vecin.
Incerc sa evit orice clinci, cu oricine, ma treceti la ignore la fel voi face si eu.
Cum ati ajuns la concluzia asta? Si daca era trecuta print-un alt cap nu era o realizare exceptionala? Ma dezamagiti cu ironia d-voastra.
In rest, multa sanatate.
Buna ziua !
La o prima vedere, adaugarea prefinalilor pe acelasi radiator cu finalii, a rezolvat problema. De altfel, asa este si originalul.
Ideea este ca am fost multumit de rezultate si am decis sa continui. La indemnul @donpetru am ales varianta cu tranzistori complementari la iesire.
De asemenea cu ajutorul lui @mducu am tot vizualizat scheme dezvoltate pe acelasi subiect prezent si in cazul de fata: QUAD405.
In fine, nu este usor sa prezinti ceva original tinand cont ca acest subiect a fost foarte dezbatut/abordat de FOARTE multe persoane.
Varianta pe care lucrez acum imi creeaza probleme, de aceea am ales sa apelez la parerile dvs tehnice.
Dupa graphic par sa fie distorsiuni la racordare.
Intrebarea este : Cum pot elimina problema?
Observ ca schema nu prevede un element de reglaj pentru polarizarea tranz prefinali.  Eu as banui ca se poate inseria un semireglabil de 100 ohmi cu diodele D1 si D2, plecind de la valoarea minima (zero) a valorii in timpul reglajului, pana dispar distorsiunile de racordare. Dar sa nu se supraincalzeasaca tranzistoarele.
Va multumesc pentru sfat. Din ce am citit eu, tipologia de "current dumping" prezenta in cazul QUAD poate functiona si cu 0mA prin finali la volum mic datorita felului in care este proiectata. Oricum, este doar o teorie. Asteptam urmatoarele pareri. 🙂
Parerea mea e sa transpui schema in practica si sa te convingi de acele distorsiuni de racordare pentru ca, din experienta, s-ar putea sa faci zeci de mii de simulari si una din ele sa fie chiar aia buna chiar daca programul de simulare nu arata asta!
Acum 3 ore, Mircea Radulescu a spus:
Exact! Dar asta se aplica NUMAI la schema originala... Quad 405 nu are un etaj final clasa B clasic... Ultima schema prezentata, nu are nici in clin, nici in maneca cu Quad... din pacate... este o banala schema de amplificator in clasa AB, cu simetrie totala si operational la intrare.
Tensiunea pe grupul de diode D1, D2 trebuie sa fie 0.6xnumar jonctiuni de polarizat.
Ma bucur ca nu a ramas varianta mic si fierbinte asa cum sugera un respectabil domn.
Editat de vijelie02
  • Haha 1
