Ce parere aveti de modelul SW-HF 5.1 5005 de la Genius?
http://www.westech.sk/?cls=stoitem&stiid=15856
Am ascultat unul prin supermarket si se aude binisor.
Are si telecomanda.
Daca il stingi (standby) volumul se duce singur la zero,iar la repornire volumul merge singur aproape
de pozitia avuta atunci cand a fost stins.
Unii zic ca nu distorsioneaza la nivel mare.
Ma bate gandul sa-mi iau unul.Costa cam vreo 300 RON.
Are si multiple intrari .O intrare 5.1 ptr. DVD si alte 3 intrari stereo.
Mersi.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/
Dar uitati ce spun specificatiile:
Power Rating : 150 watts RMS
Subwoofer: 75 watts
Satellites & Center: 15 watts each at THD10%
Drivers :
Subwoofer: 6.5? Woofer
Front Speaker: 4? Full Range and 1? Dome Tweeter
Rear Speaker: 3? Full Range and 1? Dome Tweeter
Center: Two 4? Full Range and 1? Tweeter
Impedance:
Woofer: 8 Ohms
Satellites & Center: 8 Ohms
Fuse:
AC 250V/2A (Local Voltage: 220~240V)
AC 125V/3.15A (Local Voltage: 100~120V)
AC IN: AC transformer built-in
Frequency Response: 40Hz ~ 20KHz
Signal-to-Noise Ratio: 85 dB@
Daca presiunea acustica creata de sistem in camera dvs. este suficienta iar calitatea sonora acceptabila atunci puteti sa-l cumparati. In caz contrar puteti cauta solutii mult mai bune. Personal, nu as cumpara asa ceva.
LATER EDIT: Puterea acestui sistem nu cred ca prinde 50Wrms = subwoofer + satelitii
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-9771
Evident ca nu cred in cei 75 W + 5x15W.(calitativ vorbind)
Sa fie si doar 30W + 5x5 W,dar fara THD mare,ar' fi acceptabil ptr. o camera mare.
Si TDA7294 are 10% distorsiuni la 100 W si 0,5% la 70 W. (asa scrie parca in datasheet).
Facand analogie cu distorsiunile lui TDA7294,cam cat or' fi distorsiunile la Genius la aceasta putere?:
30W + 5X5 W.
Daca THD-ul e mic poate se preteaza ptr. o camera mare.
Mersi.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-9777
Daca ne referim la volumul incaperii un rol important aici il are SPL-ul sistemului si cu ce distorsiuni THD se atinge SPL.
Pentru obtinerea pe difuzorul subwoofer-ului a unui THD cat mai mic (sub 1%) trebuie ca sursa de alimentare a sistemului 5.1 sa fie foarte bine dimensionata. Multe din specificatiile redate de producator (in afara de dimensiunile sistemului) nu sunt adevarate. Multe firme in ziua de azi fac orice ca sa-si vanda produsul: il fac cat mai ieftin si cu specificatii spectaculoase. Asadar nu trebuie sa luam ca bune acele specificatii.
Apoi daca ne uitam mai atent la urmatoarele specificatii:
Subwoofer: 220 x 424 x 332 mm Center: 332 x 163 x 153 mm
Front Speaker: 140 x 233 x 163 mm Surround Speaker: 120 x 213 x 138 mm
Subwoofer-ul este bandpass. La aceste dimensiunii, tinand cont si de compartimentul circuitelor electronice pentru alimentare amplificatoare, puterea acestuia nu depaseste 30...40Wrms AES. Sateliti foarte probabil au in jur de 2W. In anumite situatii, intr-o incapere obisnuita, "zgomotul" facut de acest sistem poate sa fie de ajuns, in alte situatii, cu pretentii mai mari, nu.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-9802
Am eu un sistem de tipul acesta si eu personal sunt multumit de cum se aude. La mine e conectat pe o placa de sunet Creative Audigy. La volum maxim consumul se apropie de 100W de la retea (masurat cu un wattmetru de tipul asta).
Pt o camera obisnuita e arhisufuciet. La bani asta este o afacere destul de buna. first.gif
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-9829
Mi-am luat azi si eu unul,pe negru.
300 RON
Mi-au dat garantie doi ani.
M-am cam saturat prin camera de boxe monstru.
La chefuri in curte sau sali e altceva.Acolo trebuie putere.
Ptr. camera zic ca e OK cum si cat de tare se aude.
Sa vedem fiabilitatea.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-9836
  • 10 months later...
Va salut.Trebuie sa repar subwooferul de la acest Genius.Nu mai primeste nicio comanda,nu se aprinde niciun led.Normal,am inceput cu sursa de alimentare,implicit cu traful.In secundar,are doua mufe,una cu 3 pini si una cu 5 pini.
-albastru+negru+albastru (mufa cu 3 pini) : 2x14.7Vca
-rosu+negru+rosu (mufa cu 5 pini) : 2x21.5Vca
-galben +galben (aceiasi mufa cu 5 pini) : 0V (???)
Stie cineva tensiunea de acolo (firele galbene),ce rol are pe schema si...de ce s-a ars?Tipul zice ca a lasat sistemul functional,a ramas in priza,apoi nu a mai mers.Sa desfac traful cred ca e cam greu,daca as sti acea tensiune prefer sa ii atasez un al doilea traf.Sper ca asta sa fie defectul.
Multumesc de raspunsuri.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-18425
E chiar subwoofer-ul de la Genius SW-HF 5005 ?
Nu e de la alt model ?
Eu am desfacut subwooferul si traful arata asa:
De unde ai tu cablul cu 5 fire?
Daca ai tensiuni in secundar nu are rost sa-l desfaci.
Te vei chinui mult sa-l refaci.Trust me. :hi:
Mai multe despre o problema cu acest model de Genius gasesti aici:
http://www.forum.tehnium-azi.ro/intrebaril...5005-t1473.html
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-18427
In spate nu scrie ce model este ?
Eu cred ca al tau e modelul 5000 , deci nu discutam despre acelasi model.
Sincer nu scrie,am avut senzatia ca e acelasi model.
Totusi poate tensiunile sunt asemanatoare cu al tau si ma poti ajuta.Sau daca stie altcineva...
Multumesc.
https://www.tehnium-azi.ro/forums/topic/998-genius-sw-hf-51-5005/#findComment-18430
