generator 8KW
DE CURAND AM RECUPERAT UN GENERATOR DE CURENT ALTERNATIV TRIFAZAT DE LA FIER VECHI AM REUSIT SA REPAR MOTORUL PE BENZINA INSA INTAMPIN O PROBLEMA :DESII ACESTA INVARTE GENERATORUL LA 3OOO ROT/MIN NU AM TENSIUNE LA IESIRE
AM MASURAT BOBINELE SI PAR IN REGULA ....MA INTREB DACA NU CUMVA ACEST GENERATOR A AVUT UN CIRCUIT CARE SA-I ASIGURE EXCITATIA
NECESARA MAGNETIZARII STATORULUI
DACA STITI CEVA IN LEGATURA CU ASTA VA ROG SA MA AJUTATI
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/
Tinand cont de faptul ca generatorul este de 8kW mai mult ca sigur are circuit de excitatie. Ar trebui sa verificati acest lucru ?
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8139
GENERATORUL NU ARE DECAT BORNELE DE IESIRE .... NU STIU DACA A AVUT UN CIRCUIT DE EXCITATIE IAR DACA DUMNEAVOASTRA SPUNETI CA 100% A AVUT CANDVA ATI PUTEA SA-MI DATI NISTE IDEI DE CONSTRUCTIE A UNUI CIRCUIT DE EXCITATIE (O SCHEMA ELECTRICA A UNUI ASEMENEA CIRCUIT ) ???
AM PUTEA VORBII PERSONAL PE MESSENGER DESPRE PROBLEMA MEA ? ID: prozorianu_marian
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8144
SIGLA AMPLASATA PE GENERATOR ... DUPA O EXAMINARE MAI ATENTA AM OBSERVAT CA GENERATORUL DEBITEAZA 5 KVA LA 3000 ROT/MIN 50 HZ
SI NECESITA O TENSIUNE DE EXCITATIE DE 60 V 3.6 A DAR NU STIU CE FEL DE CURENT ALTERNATIV SAU CONTINUU SA-I APLIC DE UNDE SA-L SCOT( DIN CE SURSA SA OBTIN 60 V ) BOBINELE PE CARE AR TREBUII SA APLIC TENSIUNEA DE EXCITATIE BANUIESC CA AR FII CELE ALE STATORULUI ... SUNT DOAR DOUA DISPUSE SIMETRIC PE CARCASA GENERATORULUI ELE TREBUIND MA GANDESC EU SA SE TRANSFORME CAND LE ALIMENTEZ CU 60 V 3.6 A IN ELECTROMAGNET PENTRU CA GENERATORUL SA FUNCTIONEZE.
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8153
Continu.
La placa de borne ce aveti,cate si ce scrie pe ele?Poate are o iesire de cca.60V,care pot fi redresati,pentru excitatie.
P.S.
De ce scrieti numai cu majuscule?
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8164
Are 6 borne la iesire si una pe carcasa dar nu scrie nimic pe nici una doar pe cea de pe carcasa e desenat semnul de impamantare .
Bornele sunt dispuse pe carcasa exact ca la un motor de curent alternativ dar pe capacul care le protejeaza nu este nici o schema cum ar fii normal
si daca spuneti ca ar trebuii sa-i aplic curent continuu dc colectoarele de pe rotor ( inelele de pe care se colecteaza tensiunea generata) sunt neintrerupte ?
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8168
Este normal.doarece,este generator de curent alternativ.Trebuie sa faceti o schita cu placa de borne,si ce anume este legat la ele.Faptul ca sunt 6 borne,poate insemna ca aveti 2 pentru curentul alternativ pentru consum,2 pentru excitatie si 2,care probabil alimenteaza redresorul necesar excitatiei.Nu are inca un inel,sectionat?
31ZB3010.pdf
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8169
Dupa cum observati in poza pe care am atasat-o pe sigla din aluminiu apare semnul de legare in stea a bobinelor si o tensiune debitata de 400V nu stiu daca e vorba de 400 V pe fiecare dintre bobine sau este vorba de tensiunea totala (suma) .
Pot sa va mai spun ca inelele de pe care se colecteaza tensiunea sunt 4 la numar sunt neintrerupte (nu sunt intrerupte ca un colector de motor cu magneti permanenti ) .
O sa masor continuitatea fiecarei iesiri sa vad de unde exact porneste ,care sunt iesirile bobinelor de pe stator etc si o sa fac o schema (un desen ) sau o schema electrica in workbench si o s-o postez pentru ca dumneavoastra sa intelegeti mi bine despre ce e vorba .
Dupa cum am observat eu schema ar arata cam asa dar ca sa fiu mai sigur am sa masor toate iesirile si corespondentele lor in interiorul generatorului.
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8176
Pe sigla respectiva ar trebui sa fie trecuta si tensiunea nominala pe cele trei faza a generatorului ? Chiar nu este trecut nimic in acest sens ?
La concluzia asta am ajuns si eu insa de unde iau cei 60V necesari excitatiei ?
Dupa aflarea tensiunilor nominale pe cele trei faze 3x....V, putem gasi o solutie de realizare a unui circuit de excitatie. La un moment dat ma gandeam ca nu cumva cele trei tensiuni sa fie chiar de 60V, dar putin probabil!!! Daca ar fi de 60V~ atunci intre faze ati avea 1,73*60=103,92V. Deci, nu cred ca sunt de 60V. In al doilea rand s-ar putea ca generatorul sa fi avut sau chiar mai are un AVR care sa ajute si la creerea tensiunii necesare aplicarii pe intrarea redresorului de excitatie, dar trebuie vazut si...confirmat.
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8194
Pe sigla apare schema de legare in stea ( ca si la motoare ) si in dreptul Y e trecuta tensiunea de 400 V ( Y 400 V ) asa ceva ...acuma nu stiu daca se refera la tensiunea totala pe care o debiteaza generatorul sau la o singura faza .
Tot pe sigla mai apare tensiunea de excitatie care este notata in felul urmator: ( EXC 60 V ) 3.6 A
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8215
Tensiunea de 400V la conexiunea stea este masurata intre faze si se numeste "tensiune de linie". Pe fiecare faza, fata de punctul comun, o sa aveti aprox.230V.
Pentru a creea tensiunea de excitatie aveti nevoie de un transformator trifazat si un redresor trifazat. Puterea nominala a transformatorului (pe partea secundara) se calculeaza cu relatia:
S=1,05*Uexc*Iexc=1,05*60*3,6=226,8 VA.
Transformatorul va fi trifazat cu primarul avand conexiunea stea si secundarul stea. Secundarul se va conecta la un redresor trifazat realizat din 6 diode 6A 200V bucata plasate pe niste radiatoare corespunzatoare.
Tensiunea de linie (intre fazele infasurari secundare) va fi:
Us=Uexc/1,73=34,68V - tensiunea de mers in gol a transformatorului va trebui sa fie mai mare decat valoarea anterior calculata.
Conductorul infasurari secundare se va dimensiona corespunzator curentului de linie determinat cu relatia:
Is=S/1,73*Us=226.8/1.73*34,68=3,78 A.
Schema de alimentare a circuitului de excitatie va arata ca in imaginea de mai jos.
https://www.tehnium-azi.ro/forums/topic/846-generator-8kw/#findComment-8217
