Diverse electronice de vanzare (aparate ,module,etc)
- 2 buc. modul filtre(crossover) ,80W , inalte / joase , noi , pret= 20lei/buc
https://i.postimg.cc/TPFj78M4/FILTRE-BOXA-1.jpg
https://i.postimg.cc/Qt7Qv6jx/FILTRE-BOXA-2.jpg
 - sistem 2.1 Logitech , model S - 00154 , lipsa dif-ul subwoofer , in rest perfect functional , optic 10/10 , pret =  50 lei
https://i.postimg.cc/y85SBFQJ/LOGITECH-FATA.jpg
https://i.postimg.cc/1zqVzf2v/LOGITECH-1.jpg
https://i.postimg.cc/G2PBk6cY/LOGITECH-2.jpg
https://i.postimg.cc/2yz1TT6t/LOGITECH-3.jpg
- Difuzor (recuperat) Tonsil (Pioneer license) , impecabil , 4W / 8 Ohm , dimensiuni 16x10 cm , pret = 15 lei
https://i.postimg.cc/j2b50n1f/dif-TONSIL-1.jpg
https://i.postimg.cc/zX3BmNt0/DIF-TONSIL-2.jpg
- Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei
https://i.postimg.cc/13Bs4Yjf/modul-radio-FM-1.jpg
https://i.postimg.cc/1XhLvpjk/MODUL-RADIO-FM-2.jpg
,- Boxa center sistem Genius , contine 2 buc difuzoare 15W / 4 Ohm inseriate , carcasa in stare foarte buna . dimensiuni 33x16x14 cm , pret = 35 lei
https://i.postimg.cc/2SZ9Kq4m/BOXA-GENIUS-2.jpg
https://i.postimg.cc/gkfN8Y17/BOXA-GENIUS-1.jpg
https://i.postimg.cc/FKvpCTrg/BOXA-GENIUS-3.jpg
 - Placa radio AM / FM , stereo , echipata cu CI ;  LA1201  ; BA1320 , CV , bara ferita , comutator game , completa ,componente originale , nu mai stiu provenienta , pret = 20 lei
https://i.postimg.cc/02JC8Tr0/placa-radio1.jpg
https://i.postimg.cc/bvq09dgm/placa-radio-2.jpg
- sasiu Rcass   National Panasonic  model RQ-432DS , perfect functional , radio MW ( 525 - 1605 Khz) , SW 1 -( 2,3 - 7 MHZ) ; SW 2 - ( 7 - 22 MHZ) ,extrem de sensibil / selectiv ,  componente originale , fara interventii , parte electronica / mecanica casetofon  impecabila , carcasa se ofera bonus deoarece lipseste geamul scalei ,are lipsa capacul bateriilor si o  parte din partea superioara + crapaturi..  ( are manerul si antena originale), pret = 40 lei
https://i.postimg.cc/3xwhGwV8/national-panasonic-cablaj.jpg
https://i.postimg.cc/kMhvCYCT/national-panasonic-mecanica.jpg
https://i.postimg.cc/Y25K93fx/afisor-1.jpg
 - modul  afisor recuperat , pret = bonus
https://i.postimg.cc/bNxMvjvz/afisor.jpg
- modul redresare, filtrare si stabilizare preamplificator din dezmembrare amplificator ROTEL RA-500
Pret = 22 Lei
https://i.postimg.cc/vmxqnRv2/preamplif-sursa-ROTEL.jpg
- Trafo retea recuperat dintr-un PA , tensiuni secundar ; 2 x 27,8V  ; 2 x 17,8V  ; 3V , dimensiuni tole 90x 70 x 45 mm, complet silentios , ecranat , pret = 40 lei
https://i.postimg.cc/gJ0gBL3r/trafo.jpg
https://i.postimg.cc/gcxWxn1Y/trafo-2.jpg
https://i.postimg.cc/0NVTQsfM/trafo-3.jpg
- PCB probe 9x7cm , 6 buc , pret = 5 lei/buc
https://i.postimg.cc/hPwbK3TD/cablaje.jpg
- Converter HDMI - AV , nefolosit (imi trebuia de fapt optic fiber / AV) , pret = 35 lei
https://i.postimg.cc/VLb0Ws0w/converter-hdmi-1.jpg
https://i.postimg.cc/0rgQBmKs/converter-hdmi-2.jpg
- Sursa tensiuni multiple : 3,3V  ;  5V ; 23V ; 30V , pret = 10 lei
https://i.postimg.cc/PqGqf1Sv/SURSA-MULTIPLA.jpg
- Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret = 130lei - negociabil
https://i.postimg.cc/xTwQLnMW/sursa3.jpg
https://i.postimg.cc/v81HnPCx/SURSA-12-V-FATA2.jpg
https://i.postimg.cc/3NLgztCv/SURSA-12-V-LAT.jpg
https://i.postimg.cc/MG8j3k2L/SURSA-12-V-INT-1.jpg
- Placa de baza PC , model G41T - M7 , echipata cum se vede in poze (procesor ;cooler ; memorii ),perfect functionala , pret =  30 lei
https://i.postimg.cc/zvhd3gMM/PLACA-DE-BAZA-1.jpg
https://i.postimg.cc/cLhFKZ9s/PLACA-BAZA-2.jpg
https://i.postimg.cc/66ZzrCjb/PLACA-BAZA-3.jpg
https://www.tehnium-azi.ro/forums/topic/7649-diverse-electronice-de-vanzare-aparate-moduleetc/
Au ramas valabile cele de mai jos :
Pret = 22 Lei
  • 4 weeks later...
La 16.10.2024 la 10:48, barsan a spus:
Salut. Ma intereseaza placa,  Cost estimat cu tot cu transport? Posta sau cum iti este usor, plata pe card inainte.
OK ,  transportul  nu poate depasi 15 - 20 lei , deci 35 lei - total
  BONUS Modul (recuperat din RCass Unitra Eltra)) radio FM (65,5 - 73 MHz) , echipat cu CI - TA 8164 (Toshiba) , pret = 7 lei
Livrare Posta  , suma totala in cont ,dupa ce am adresa dvs. si fac AWB -ul ,ca sa va spun exact cand pleaca ..
Multumesc pentru interes.
Se adauga , ACTUALIZARE  :
- Placi PCB perforate , 7x5cm , 10 buc , pret = 2,5lei / buc
https://i.postimg.cc/XNywhzbS/PCB-7x5-cm.jpg
 - Set de șurubelnițe 12 în 1, șurubelniță cu formă specială, diverse capete de șurubelniță, torx , Y , triungi , cruce ,etc  pret = 15lei
https://i.postimg.cc/rF5yvSsw/surubelnite-speciale-1.jpg
https://i.postimg.cc/3JZ5X9Wm/surubelnite-speciale-2.jpg
 - Suport telefon / tableta , alb - 2buc , negru -  1buc , mov - 1 buc , pret = 10lei/buc
https://i.postimg.cc/85qr5VqS/suport-tel-1.jpg
https://i.postimg.cc/hPnf3Mnp/suport-tel-2.jpg
https://i.postimg.cc/13nh0hdT/suport-tel-3.jpg
https://i.postimg.cc/sxqKs8JQ/suport-tel-4.jpg
- Retroproiector 3M , portabil ,tip valiza ,  perfecta stare , (oglinda fresnell) pret= 95 lei , insotit de manual utilizare , certificat garantie, folosit foarte putin la cateva prezentari ,cu ani in urma..am 2 buc ,la mine aduna praful degeaba
https://i.postimg.cc/ZY9qwxvW/retroproiector-1.jpg
https://i.postimg.cc/N0yn3F6k/retroproiector2.jpg
https://i.postimg.cc/bNBHKT34/retroproiector-fresnell.jpg
https://i.postimg.cc/hPTT5BQQ/retroproiector-manual.jpg
Pret = 22 Lei
- motor electric  industrial , 380V , 0,12 KW , recuperat , montat pe suport textolit cu pufere de cauciuc ( l-am recuperat perfect functional - lucra pentru o pompa de solutii , partea filetata a axului este de M8), pot face pentru un eventual doritor probehttps://i.postimg.cc/CMmr2ghw/intrrupator-trifazic-1.jpg , eventual cu un condensator pentru alimentare la 220v) detalii in poze ,pret =   80 lei
https://i.postimg.cc/y8VmCJv5/motor-trifazic.jpg
https://i.pos pe vremuritimg.cc/8PCyL0Vs/motor-trifazic-1.jpg
https://i.postimg.cc/855HL7q9/motor-trifazic-eticheta.jpg
https://i.postimg.cc/8kdYDvTB/motor-trifazic-3.jpg
-  intrerupatoare  trifazic ( cred ca le spunea PACO pe vremuri) , recuperate , contacte "zdravene" , pret = 20 lei ,cel mare , 15 lei cel mic  , ambele = 30 lei
https://i.postimg.cc/3xHGCksN/intrerupator-trifazic-2.jpg
- hands-free bluetooth  pentru masina ,practic nefolosit , doar probat , functioneaza ireprosabil , cu cablu incarcare +manual utilizare, pret = 70lei
https://i.postimg.cc/BbB7MsP9/HANDS-FREE-1.jpg
https://i.postimg.cc/HWFbPF4F/HANDS-FREE-2.jpg
- Sursa reglabila SMPS , 0-12V / 5A , home made , (echipata cu LM 317 + 2 xTIP 3055), pret =  110lei
- Pistol lipit , 100W , folosit(aproape deloc) , perfect functional , pret = 60 lei
https://i.postimg.cc/vHCqFVRL/pistol-lipit1.jpg
https://i.postimg.cc/BtfKNsyD/pistol-lipit2.jpg
- motor Bosch + modul comanda , recuperat dintr-un storcator de fructe putin folosit, pret = 35 lei
https://i.postimg.cc/8cnyWp93/motor-Bosh.jpg
https://i.postimg.cc/j2WHpz3g/motor-bosch-1.jpg
https://i.postimg.cc/rydYXW42/motor-bosch-2.jpg
Se adauga la cele de mai sus:
- Lupa atelier POWERFIX , diametru 8cm , reglabila , brate cu clips , lumina led , nu este zgariata / matuita, pret = 45 lei
https://i.postimg.cc/nz5HkjDn/lupa-0.jpg
https://i.postimg.cc/vm09GzpX/lupa-1.jpg
https://i.postimg.cc/VN00nCvW/lupa-2.jpg
https://i.postimg.cc/T1sXVppn/lupa-3.jpg
 - Suport reparatii / montaj cablaje , pret = 25 lei
https://i.postimg.cc/7LXBjjwL/suport-cablaj-1.jpg
https://i.postimg.cc/ZY1CrRpT/suport-cablaj2.jpg
https://i.postimg.cc/Lsc8jQgx/suport-cablaj-3.jpg
 - prelungitor GTV banc / birou , 3 prize + 2 iesiri USB , calitate , pret = 50 lei
https://i.postimg.cc/6QYDX8tn/prelungitor-1.jpg
https://i.postimg.cc/nhQ4xgxk/prelungitor-2.jpg
https://i.postimg.cc/Y25g38YL/prelungitor-3.jpg
https://i.postimg.cc/1tS2wDBk/prelungitor-4.jpg
-  COMBINA  audio monobloc RECOR , stereo , telecomanda - [ON ; OFF ; VOL] ,stare perfecta optic(fara zgarieturi , sparturi ,etc) ,perfect functional : radio ; pik-up ; dublu cass .
RADIO analog AM FM , selectiv, sensibil ; PIK-UP , doza perfecta , platan 33 - 45 rpm , CASS dublu , mecanica autorevers (una din parti) ,posibilitate inregistrare rapida , curele schimbate recent , EQ 5 cai . Fara boxe /difuzoare . Va ajunge la dezmembrari in scurt timp.. deoarece ocupa loc   ,PRET = 75 lei
https://i.postimg.cc/Fs6dzfhC/RECOR-FATA.jpg
https://i.postimg.cc/Z5y9dTRb/RECOR-LAT-1.jpg
https://i.postimg.cc/wv93ZLkM/RECOR-LAT-2.jpg
https://i.postimg.cc/3rSWfy0r/RECOR-SPATE.jpg
  • 2 months later...
Au ramas valabile (actualizare):
Pret = 22 Lei
- motor electric  industrial , 380V , 0,12 KW , recuperat , montat pe suport textolit cu pufere de cauciuc ( l-am recuperat perfect functional - lucra pentru o pompa de solutii , partea filetata a axului este de M8), pot face pentru un eventual doritor probehttps://i.postimg.cc/CMmr2ghw/intrrupator-trifazic-1.jpg , eventual cu un condensator pentru alimentare la 220v) detalii in poze ,pret =   75 lei
Lupa atelier POWERFIX , diametru 8cm , reglabila , brate cu clips , lumina led , nu este zgariata / matuita, pret = 35 lei
 - prelungitor GTV banc / birou , 3 prize + 2 iesiri USB , calitate , pret = 30 lei
RADIO analog AM FM , selectiv, sensibil ; PIK-UP , doza perfecta , platan 33 - 45 rpm , CASS dublu , mecanica autorevers (una din parti) ,posibilitate inregistrare rapida , curele schimbate recent , EQ 5 cai . Fara boxe /difuzoare    ,PRET = 75 lei
Pret = 22 Lei
