Intrebare utilizare NE5532 !
Din foaia de catalog a NE5532 acesta are in structura lui 2 amplificatoare operationale. Daca la un moment dat folosim doar un amplificator operational din capsula NE5532, cu celelalt ce facem, il lasam pe cablaj pur si simplu in aer ? E suficient asa ? :scratchchin:
https://www.tehnium-azi.ro/forums/topic/7626-intrebare-utilizare-ne5532/
În general vă puteți informa de aici:
This is a trickier than it looks. If an opamp is overdriven, the output stage will saturate at one of the supply rails, and the op-amp will consume excess power. Many common configurations of an unused upamp will overdrive it.
If the terminals are all left unconnected, there is a real risk that stray electrostatic fields will cause an input to go outside the supply rails. This can cause latch-up and destroy the whole chip. Even if latch-up does not happen, a dc field may cause saturation and power waste. In addition, the amplifier may amplify an ac field and, if overdriven, will heavily modulate its own supply current and cause crosstalk to other amplifier(s) on the chip.
Some users connect one input to the positive supply and the other input to the negative supply. This again saturates the output and wastes power; it may also exceed the differential input voltage rating and damage the device. Even if damage does not occur, some input stages draw several tens of milliamps under these conditions, wasting even more power.
Grounding both inputs, or shorting them together at some other potential, also causes the output stage to saturate, since the offset voltage of an op-amp is never exactly zero; shorting them together and not biasing them has the same latch-up risks that we have already mentioned.
What we should do is connect the device as a follower (output to inverting input1) and connect the non-inverting input to a potential somewhere between the supply rails. With a dual-supply system, ground is ideal, but connecting to the positive or negative supply of a single supply system will cause saturation and the resulting power waste if the offset voltage has the wrong polarity. The "potential somewhere between the supply rails" may be any point in the circuit with a suitable potential, since the loading caused by the op-amp input is minimal. For diagrams see the linked article.
Or you might use it as a buffer amplifier in a part of your system that does not need one but might perform slightly better if it had one.
1 If the op-amp is a current-feedback type, or has a minimum stable Acl >1 the connection should be made with a 100 kΩ resistor rather than a short-circuit to ensure stability and prevent possible oscillation.
https://www.tehnium-azi.ro/forums/topic/7626-intrebare-utilizare-ne5532/#findComment-84527
Mersi, am tradus mai jos cu Google Translate:
Citat
Acesta este mai complicat decât pare. Dacă un amplificator operațional este supraalimentat, treapta de ieșire se va satura la una dintre șinele de alimentare, iar amplificatorul operațional va consuma exces de putere. Multe configurații comune ale unui upamp neutilizat îl vor supraalimenta.
Dacă toate bornele sunt lăsate neconectate, există un risc real ca câmpurile electrostatice parazite să determine o intrare să iasă în afara șinelor de alimentare. Acest lucru poate provoca blocarea și distrugerea întregului cip. Chiar dacă blocarea nu are loc, un câmp de curent continuu poate cauza saturație și pierderi de energie. În plus, amplificatorul poate amplifica un câmp de curent alternativ și, dacă este suprasolicitat, își va modula puternic propriul curent de alimentare și va provoca diafonie cu alte amplificatoare(e) de pe cip.
Unii utilizatori conectează o intrare la sursa pozitivă și cealaltă intrare la sursa negativă. Acest lucru saturează din nou producția și irosește energie; de asemenea, poate depăși tensiunea nominală diferenţială de intrare și poate deteriora dispozitivul. Chiar dacă nu se produce deteriorarea, unele trepte de intrare consumă câteva zeci de miliamperi în aceste condiții, irosind și mai multă putere.
Împământarea ambelor intrări sau scurtcircuitarea acestora la un alt potențial, de asemenea, provoacă saturarea etapei de ieșire, deoarece tensiunea de compensare a unui amplificator operațional nu este niciodată exact zero; scurtcircuitarea lor și nu influențarea lor are aceleași riscuri de blocare pe care le-am menționat deja.
Ceea ce ar trebui să facem este să conectăm dispozitivul ca urmăritor (ieșire la intrarea inversoare1) și să conectăm intrarea neinversătoare la un potențial undeva între șinele de alimentare. Cu un sistem cu alimentare dublă, împământarea este ideală, dar conectarea la sursa pozitivă sau negativă a unui singur sistem de alimentare va provoca saturație și pierderea de energie rezultată dacă tensiunea de compensare are polaritatea greșită. „Potențialul undeva între șinele de alimentare” poate fi orice punct din circuit cu un potențial adecvat, deoarece încărcarea cauzată de intrarea amplificatorului operațional este minimă. Pentru diagrame vezi articolul legat.
Sau l-ați putea folosi ca amplificator tampon într-o parte a sistemului dvs. care nu are nevoie de unul, dar ar putea funcționa puțin mai bine dacă ar avea unul.
1 Dacă amplificatorul operațional este de tip cu feedback de curent sau are un Acl minim stabil >1, conexiunea ar trebui făcută cu o rezistență de 100 kΩ, mai degrabă decât cu un scurtcircuit, pentru a asigura stabilitatea și a preveni posibilele oscilații.
Deci, la un NE5532 alimentat simetric daca unesc minusul cu iesirea iar plusul la masa, e suficient !!! Eu asa inteleg !
Editat de elco
https://www.tehnium-azi.ro/forums/topic/7626-intrebare-utilizare-ne5532/#findComment-84528
