Tranzistorii...
  • Răspunsuri 72
Posted Images
Adica daca nu pun o rezistenta de polarizare, nu functioneaza tranzistorul?
Da, la un semnal,sub aceasta tensiune,nu va comanda un curent de colector.
Si aceasta de pune intre baza si emitor?
Nu,intre sursa si baza.
https://www.tehnium-azi.ro/forums/topic/721-tranzistorii/page/5/#findComment-7448
Deci sa inteleg ca daca tensiunea este cat cea de deschidere, aceasta rezistenta este optionala?
N-am inteles,ce vreti sa spuneti.
Si tensiunea de deschidere variaza in functie de tipul tranzistorului?
Da,este diferita la siliciu(mai mare) fata de germaniu.
https://www.tehnium-azi.ro/forums/topic/721-tranzistorii/page/5/#findComment-7462
Ma refeream daca pot renunta la rezistenta, sau este necesara pentru functionarea tranzistorului?
Daca nu polarizati initial baza,aceasta va deschide,doar cand emnalul va depasi 0,7V si atunci va apare curentul de colector.
https://www.tehnium-azi.ro/forums/topic/721-tranzistorii/page/5/#findComment-7470
Da.
Uite:
Transistors are categorized by:
  • Semiconductor material : germanium, silicon, gallium arsenide, silicon carbide, etc.
  • Structure: BJT, JFET, IGFET (MOSFET), IGBT, "other types"
  • Polarity: NPN, PNP (BJTs); N-channel, P-channel (FETs)
  • Maximum power rating: low, medium, high
  • Maximum operating frequency: low, medium, high, radio frequency (RF), microwave (The maximum effective frequency of a transistor is denoted by the term fT, an abbreviation for "frequency of transition". The frequency of transition is the frequency at which the transistor yields unity gain).
  • Application: switch, general purpose, audio, high voltage, super-beta, matched pair
  • Physical packaging: through hole metal, through hole plastic, surface mount, ball grid array, power modules
  • Amplification factor Hfe (transistor beta)[13]
Thus, a particular transistor may be described as: silicon, surface mount, BJT, NPN, low power, high frequency switch.
http://en.wikipedia.org/wiki/Transistor
https://www.tehnium-azi.ro/forums/topic/721-tranzistorii/page/5/#findComment-7882
La semiconductoare trebuie mentionat noul material obtinut prin "amestecul" siliciului
cu germaniul. SiGe.
Are tensiunile de deschidere proprii germaniului si rezistenta siliciului.
Au inceput sa apara tranzistori ce lucreaza lejer la frecvente de 25GHz.Adio diodelor Gun si Esaki.
Si fanii audio o sa se bucure.Ampificatoarele nu o sa mai aibe "f?sul" specific siliciului.
Imi inchipui ce o sa fie peste cativa ani si in domeniul microprocesoarelor.Vcore de 0,16V.
Suna interesant.
https://www.tehnium-azi.ro/forums/topic/721-tranzistorii/page/5/#findComment-7895
