TheFilmMachine
M-am gandit sa analizam acest program,si, in consecinta,sa discutam doar despre acest program in acest topic.
Nu am mai lucrat cam de un an cu el dar imi place ptr. ca are all inclusive.
Se poate descarca de aici:
http://members.home.nl/thefilmmachine/
Tot aici gasiti si un How to use.
Features :
  • Easy to use, wizard-like user friendly interface
  • Simple AVI to (S)VCD & DVD conversion
  • Full information about AVI-file
  • Automatic splitting of the movie
  • Automatic bitrate calculation
  • NTSC to PAL conversion
  • Aspect ratio selection
  • Audio downsampling and bitrate selection
  • The possibility to edit the Avisynth script as first step of the conversion process
  • Permanent subtitles support
  • Automatic chapter extraction and creation
  • Detailed logging
  • A ready to use bin\cue CD image is created after conversion
  • Immediate burning of DVD when doing AVI to DVD conversion (Nero 6.3 and higher must be installed)
  • Immediate burning of DVD when doing AVI to DVD conversion (Nero must be installed) CHANGED
  • Automatic program shutdown
  • Works on all versions of Microsoft Windows, including Windows XP
Imi place si ptr. ca da o alta nuanta,mai placuta,stream-ului audio,folosind binecunoscutul program BeSweet.
In concluzie,mie mi-aplacut. Nu are insa posibilitatea de a taia pasajele nedorite,un lucru important daca vrei sa faci un DVD dintr-o filmare cu camera.(cel putin eu nu am vazut sa aiba aceasta posibilitate).
Inca un plus: e free. :biggrin:
Ce parere aveti de acest soft?
Mersi.
https://www.tehnium-azi.ro/forums/topic/696-thefilmmachine/
E bun! Nu foarte...dar nici nu e prost. Eu am obiceiul de a folosi mai multe softuri pentru acelasi lucru. In cazul editatii video, folosesc Pinnacle Video Studio 8, DVD Movie Factory, Windows Movie Maker si altele, fiecare facand cate ceva, asa ca acesta se va adauga la "colectia" mea.
https://www.tehnium-azi.ro/forums/topic/696-thefilmmachine/#findComment-6505
Ce imi place la el foarte mult este nuanta calda a sunetului care rezulta.
Nu stiu ce prelucrari sufera stream-ul audio,aici e maestru Besweet,dar se simte diferenta.
Adica am prelucrat acelasi material filmat si cu alte programe,dar nici unul nu a dat la final sunetul asa de bine,fara zgomot de fond,si mult mai dinamic,fata de sunetul original cu zgomot de fond si plat.
Acelasi "fenomen" audio este si la AVI2DVD,dar caruia i-am deschis un topic separat,ca merita. :biggrin:
https://www.tehnium-azi.ro/forums/topic/696-thefilmmachine/#findComment-6512
desi After Effects are mai multe caracteristici care ii dau acest sunet "cald", una dintre ele, cea mai simpla, si poate cea mai importanta impreuna cu noise removal, este frecventa sau cam asa ceva. Unele soft-uri o au, altele nu. Incercati si jucati-va cu ea. Majoritatea sunetelor sunt in 44.000 Hz sau ceva de genul. pe 41.000 si 35.000 au cele mai bune rezultate. Incercati si spuneti-mi ce iese.
https://www.tehnium-azi.ro/forums/topic/696-thefilmmachine/#findComment-9142
