Pareri incinte Heco Victa Prime 702
Va salut colegi forumisti,
as dori cat mai multe detalii despre incintele Heco Victa Prime 702, eventual daca cineva le detine si le poate descrie mai detaliat...
Si cum credeti ca s-ar imperechea cu un amplificator cu 2 kit-uri cu 2xTDA7294 in punte alimentat la +/-35 Vcc + un preamplificator KIT101.
Multumesc anticipat!
"3-way floorstanding speaker, bass reflex configuration with double bass driver
HECO?s Victa Prime 702 is the largest floorstanding speaker in the series and it is equipped with three woofer chassis, two of which operate in a double bass configuration to ensure a powerful foundation for the bass range. The cones used for the 170 mm woofer and midrange drivers have been manufactured from HECO?s tried and tested long-fibre kraft paper. A 25 mm silk dome, which features ferrofluid cooling for improved power handling, is equipped with a short horn attachment for enhanced transition to the midrange. Lightly rounded sides, which have been meticulously manufactured from layers of glued and moulded MDF panels, provide the speaker with a modern appearance. The extremely low-resonance structure offers optimum conditions for the chassis and bass reflex coordination."
Descriere:
  3 way Bass reflex Difuzoare: 2 x 170 mm woofer,
1 x 170 mm woofer-midrange
1 x 25 mm dome-tweeter Raspuns in frecventa: 25 - 40000 Hz Sensibilitate (2,83V/1 m): 91 dB Putere RMS: 170W Impedanta nominala: 4 - 8 Ohms Frecventa crossover: 350 / 3250 Hz Dimensiuni: 203 x 1052 x 315 mm Alte caracteristici: Bi-wiring/Bi-amping-Option Putere dinamica: 300W Tip boxe: Boxe de podea
Editat de laurentiu.z
https://www.tehnium-azi.ro/forums/topic/6399-pareri-incinte-heco-victa-prime-702/
