Constructie osciloscop cu tub B7S2 RFT homemade CRT
Nardu
   Am un tub B7S2 RFT, nou. Am si tubul de ecranaj original. Nu am soclu si mufa pt. anod, dar se gasesc solutii.
   Date tub:
B7S2 (VEB Funkwerk Erfurt) - https://goo.gl/Xadh5J
B7S2 (FUNKAMATEUR) - https://goo.gl/jAs0lg
   Doresc sa construiesc un osciloscop cu acest tub.
   Am cercetat mai multe constructii prezente pe net, din diferite publicatii cat si documentatii osciloscoape industriale:
Osciloscop miniatural - Elektronika praktyczna 2006 - https://goo.gl/G9izf8
Elektorscope - Elektor 1976-77 n.29-23 - https://goo.gl/ETVmMU
Mini osciloscop - Sperimentare 1969 - https://goo.gl/ubbAfM
Miniaturowy oscyloskop 5 Mhz - Mlody Technik 1982 - https://goo.gl/HTl8LQ
Oscilloscope 10Mhz - Electronics Today International 1982 - https://goo.gl/jHHUWT
Oscilloscope 10Mhz dual - Electronics Today International 1990 - https://goo.gl/gbd3T9
Oscilloscope 10-15 Mhz - Nuova Elettronica 045_046 - https://goo.gl/cCcvOH
Oscilloscope Hameg HM203 sch - https://goo.gl/DZA9IL
Osciloscop - Amaterske Radio 72 - https://goo.gl/hvDbxy
Osciloscop 3 Mhz - Amaterske Radio 76 - https://goo.gl/I9e67g
Osciloscop 10 Mhz - Amaterske Radio 78 - https://goo.gl/RLtGrl
Oscilloscope 5Mhz - Amaterske Radio 82 - https://goo.gl/J54c9c
Osciloscop - Praktyczny Elektronik 1994-07 - https://goo.gl/QBvOZM
Osciloscop - Radio Electronik 80 (Tehnium Al.82) - https://goo.gl/7cTidP
Osciloscop - Selezione Radio 81 - https://goo.gl/lYvFxP
Osciloscop - Selezione Radio 82 - https://goo.gl/5zEUxH
Osciloscop - Tehnium 98 S.Naicu, Ghe.Codarla - https://goo.gl/2YGVzk
Osciloscop - Tehnium 84 M.Spirescu - https://goo.gl/WPVnDH
Osciloscop 5Mhz - Sperimentare 1982_09 - https://goo.gl/CZF2wX
Osciloscop HM412 - https://goo.gl/MfUYFL
Osciloscop tutorial - Amaterske Radio 72 - https://goo.gl/Eh97Fk
Osciloscop 10 Mhz EO211 B7S2 RFT - https://goo.gl/7JPs0n
Osciloscop 10 Mhz EO211 B7S2 RFT sch - https://goo.gl/hYazXY
Oscyloskop 5 Mhz mini 5-A Unitra B7S2 RFT - https://goo.gl/BWZlvN
Oscilloscope RFT EO213 - https://goo.gl/PV1j2Y
DIY Osciloscop Slovenia - http://users.triera.net/zupanbra/osciloskop/osciloskop.html
Osciloscop Cehia - http://www.belza.cz/measure/skop-p.htm
Osciloscop 10Mhz dual - http://michaelgellis.tripod.com/scope.html
Video monitor, partea de alimentare B7S2 - http://www.elektronikpage.net/videomonitor/
   Eu m-am orientat la : Oscilloscope 10Mhz dual - Electronics Today International 1990 - https://goo.gl/gbd3T9, mi se pare mai "aerisit".
In atasament sunt schitele extrase.
   Vreau un sfat din partea celor mai experimentati care au mai construit asa ceva, in primul rand cu partea de alimentare tub si amplificatoarele finale cat si alte aspecte privind constructia. .
  Urmaresc si cele 2 topicuri cu subiect similar :
http://www.tehnium-azi.ro/topic/6036-gelectronic-500-mhz-homemade-oscilloscope-crt-d13-450gh/
http://www.tehnium-azi.ro/topic/6104-ajutor-constructie-osciloscop-pentru-tubul-catodic-telefunken-d9-10gh/?hl=oscilloscope
Tubul B7S2 este destul de bun pentru realizarea unui osciloscop tranzistorizat.
Eu am folosit pini scosi din conectori sau alte socluri fara sa construiesc un soclu.
I-am izolat cu varnish.
Am studiat si eu pe vremuri un proiect asemanator, derivat dintr-un osciloscop
  made in China. Este o schema fezabila. Incepeti cu realizarea cutiei,
  panou fata si spate doar cu decuparea pentru tubul CRT. Montati tubul,
  transformatorul de retea, si alimentatorul. Construiti un modul de inalta tensiune
  cu comenzile tubului, etc.
Aveti documentatie bogata. Studiati si realizarile mele expuse pe forum:
precum si  http://www.tehnium-azi.ro/topic/442-osciloscoape-home-made/page-2 postarea #28
 Se pot vizualiza schemele pe site-ul propriu:         http://www.freewebs.com/gelectronic
 Eu am construit 6 osciloscoape, fiecare a durat de la 1an la 2 ani. Din pozele mele
  vedeti si designul realizat.
Spor la lucru ?i r?c?ial?. Verificati mai intii daca la 6V filamentul este de un rosu aprins.
 Am testat tuburi diverse si cele la care nu straluceste filamentul au aer in ele.
   Dl. @gsabac, va multumesc pt. replay.
   Imi cer scuze ca nu am nominalizat  http://www.freewebs.com/gelectronic. L-am remarcat  de mult timp fiind interesat de Art Osciloscop
   Trebuie sa va spun ca vazand 50Mhz, mi s-a parut targhet-ul prea mare pt mine avand in vedere ca sunt un hobist, Domeniul pe care il vizez fiind JFrev, audio, instrumente muzicale.
   @gsabac, m-ati pus pe ganduri: tubul il am la "naftalina" de vreo 4 ani si l-am probat numai la continuitatea filament cand l-am primit. Asa ca am inseriat cu un EL34 la 12V (ce am avut la indemana). Se aprinde imediat. Rezultatul in imagini. Eu zic ca e bine.
   Dvs.ce pare aveti? Sa stiu daca continui sau caut al tub.
   Completare surse:
Oscilloscope 10Mhz - ETI 1982 - https://goo.gl/DK7Wtg- complect lipsea Part.3
Osciloscop - Tehnium H.Bucnic 79 - https://goo.gl/TGLg7f- o solutie hibrid
   Oscilloscope - ETI_1990 Completari si erori in schite, text
Oscilloscope - ETI_1990 hints-1990-07 - https://goo.gl/zWkQkM
Oscilloscope - ETI_1990 errata 1990-08 - https://goo.gl/BAejWU
Eu am scris foarte clar:  "Verificati mai intii daca la 6V filamentul este de un rosu aprins."
Intrebati, inainte sa probati ceva ce nu sunteti convins ca este bine,
 sau nu ati mai testat.
A-ti pus la 12V un tub CRT de 6,3V si 0,34A si o lampa EL34 la care
filamentul se alimenteaza la 6,3V dar cu un current de 1,5A. Ca rezultat
tensiunea de filament a CRT-ului a fost cam mare. Se vede dupa
iluminarea filamentului. Nu este nici o problema, nu ati stricat nimic.
 Tubul este bun.
Va intreb ce experienta aveti in proiectarea si constructia de
 aparate electronice. Am vazut modulele muzicale de pe Google+, le-ati
 construit cu forte proprii ?
Postati ce ati realizat pina acum la osciloscop, ce materiale aveti, ce greutati intimpinati.
La nevoie apelati la forum, chiar cu citeva postari pe zi.
Vrem poze, scheme desenate de dvs. pe calculator sau de mina.
Unele scheme pe care le-ati ales au greseli sau greseli de redactare.
De aceea trebuiesc actualizate si notate cu componentele de care dispuneti.
Trebuiesc actualizate si unele componente care nu se mai gasesc.
Alimentatorul este o relicva antica.
Am vazut istoricul osciloscopului dvs. pornind de acum 3-4ani.
Am vam vazut si incercarea de simulare a redresarii cu doua aternante si diode zener.
Schema de convertor cu tranzistori, care are acest redresor se bazeaza pe limitarea in convertor
prin excitatie,beta tranzistorilor, tensiunea de alimentare, dar nu este fezabila, este un experiment.
La nevoie plingeti dupa componente daca nu va descurcati. Incepeti cu realizarea cutiei,
Partea mecanica este cel mai dificil de realizat. Ca sa prindeti curaj, inainte construiti un modul
  de alimentare si un circuit de polarizare al tubului.  Postati o schema de alimentator pentru inceput.
Sa ma scuzati daca sunt prea insistent sau prea "direct".
 - D-le am stiut ! Am si precizat ca am folosit ce am avut la indemana. Am niste ECC82-83, becuri de scala 6.3v pe la curte dar.... Oricum am pozat repede. N-am stat sa-l fac obiect de muzeu !
 - Nu ma supar deloc.
@gsabac refer #4
   Am corectat erorile din cele 3 schite (erau marcate in  ETI_1990 hints-1990-0 si ETI_1990 errata 1990-08). Am creat bookmark-uri la pdf-ul Oscilloscope - ETI_1990 - https://goo.gl/GDoy6T
 (document nou), vezi imaginea https://goo.gl/fSqKDY, pt. o navigare punctuala si am marcat si erorile.
Editat de Nardu
Sunt utile modificarile facute pe scheme, mai ales ca nu sunt clare
  conexiunile la masa si la jonctiuni . Si eu am depistat o greseala de
  redactare la alimentator, postarea #1 ultima poza, toate tensiunile
  componentelor legate la catod sunt negative, nu pozitive.
Acest tub functioneaza cu tensiune negativa de circa -500V...-600V pe
 catod si plus +500V...+1000V pe anodul de accelerare.
Toate tuburile CRT au acest aranjament V+/V- pentru a facilita tensiuni
  de deflexie din amplificatorii alimentati fata de masa.
Schemele recomandate de mine pentru polarizarea tubului sunt postate
 in atasamente. La convertor mai trebuie lucrat iar arcul de conectare
 la anodul de accelerare trebuie izolat intr-un capison de plastic. Atentie
 caci se foloseste o conexiune speciala care rezista la peste 1KV atit la
 anod cit si spre electrozii tubului si filament.
Desenati pe calculator sau pe hirtie, scheme proprii, cu componentele
  pe care le aveti, sau care se pot achizitiona.
Succes !
   Corectie am facut numai la cele referitor la ETI-90.
   Schema de alimentare de pe http://www.radiomuseum.org/tubes/tube_b7s2.html
e prima pe care am gasit-o . Mai am una ( http://www.elektroda.pl/)  daca imi aduc aminte tot la B7S2 se refera ( verific in history , bookmarks browser ).
   Este si Osciloscop 10 Mhz EO211 B7S2 RFT sch - https://goo.gl/hYazXY  care este construit cu acest tub.
   Din Radio und Fernsehen 1966  referitor la B7S401, pe acolo ! Am sa scanez ocr sa il traduc
   Contact la anod accelerare , neamtul a gasit o solutie de proba . La cum a facut montajul , "in aer", nu cred ca la deranjat.
   Contactele originale, in poza, doar asa intamplator sa il gasesc pe la noi . Oricum am in program o incursiune pe la targ , inclusiv la vecini la Galati . Cine stie, poate !
   Personal m-am gandit la o "ventuza" de la un TV mai mic / Monitor PC.
   Practic eu am stat pe loc datorita alimentarii tubului , anodul accelerare si sursa de alimentare in ansamblu raportat la aceasta problema.
   Pregatesc acum un post despre cum vad eu constructia in general si punctual pe blocuri ce probleme vad eu si ce nu inteleg.
B7S401-Detail.pdf
 Schema atasata nu este pentru B7S2, deoarece pentru el este
  recomandata o tensiune de -500V pentru catod si max 1KV pentru anod.
Atasamentul "pdf" prezinta date tehnice pentru tubul CRT B7S401 nu pentru B7S2.
Stiti de ce proiectul acceptat de dvs. are numai +600V tensiune anodica ?
Care sunt avantajele si dezavantajele unei tensiuni mai mici, dar mai mari ?
Cum se protejeaza catodul la pornire ?
Astept postul.
    Corect . Eu l-am nominalizat pt aveam de gand sa intreb chestia cu "geometria"
   Raspuns NU la toate trei
Editat de Nardu
 - Daca va referiti la schema de la Video monitor :
 - pai atata ii da trafo invertor pe care la utilizat neamtul.
Eu am un inverter TDK-TAD424 de la un monitor LCD Philips, tai si folosesc partea din dreapta (raman si cu rezerva p. stg), curat ce nu trebuie si il o folosesc ca atare raportat la partea de Royer converter . Maine daca am timp am sa execut problema sa vad cat scoate alimentat la +12v
TDK-TAD424_schema.pdf
Geometria linearizeaza imaginea trasei de tip "butoi" sau "burta".
La tensiune mai mica pe catod sensibilitatea tubului este mai buna.
La tensiune anodica mai mica lumineaza mai slab si nu se focalizeaza
bine dar si astigmatistismul are de suferit.
La tensiuni mai mari  de catod schemele de deflexie nu mai pot asigura
  intreaga excursie de tensiune. Si frecventa obtinuta la o anumita putere
  disipata pe finali, este mai mica.
Catodul se protejeaza folosind un generator de curent constant in serie
 cu alimentarea filamentului si nu se supravolteaza.
Schema este buna si pentru osciloscop, deoarece este simpla si usor de implementat.
Sunt ceva probleme cu acest inverter. La pornire, fara sarcina da circa 2KV...2,5KV ca sa aprinda tubul CCFL.
Dupa aceea, in sarcina tensiunea scade la 800V...1200V.
El lucreaza numai cu tuburile in sarcina prin intermediul unor bucle de curent constant.
Deasemenea comanda de luminozitate poate fi digitala, caz in care este nefolosibil.
Succes !
 Daca separati doar convertorul asa cum aratati pe schema din PDF,
  el trebuie alimentat la o tensiune mai mica de 12V, pentru 600V la iesire.
Este bun un sistem de alimentare variabila cu conectarea unui divizor
potentiometric in baza tranzistorului T2. Probele se fac numai cu
rezistentele de sarcina. La inceput se regleaza potentiometrul pentru
tensiune minima, apoi se creste usor pina la 600V la iesire.
Observatie: Convertorul porneste la o tensiune reglata de citiva volti.
Schema completa ar fi cam aceea din atasament. Poate mai sunt
 necesari condensatori electrolitici pe alimentare.
Succes !
