Bun? ziua. Aceasta este plac? medie (sunt 3 una dup? alta), unitatea de comand? LE Invertec V270-S.
Are cineva foarte acela?i dispozitiv pentru a fi reparat ?i este posibil s? spunem despre valoarea rezistor R3 suflat? El se afl? ?ntre pin3 ?i U1 pin4 (LM358), care prime?te un semnal de curent electrocauter de ie?ire a senzorului. Dac? ?nc?rca?i ultima revizie (SMD), este posibil s? se m?soare rezisten?? ?ntre pin3 ?i pin15 / 16 conector JP2.
Multumesc anticipat!
Lincoln Electric V270-S:
generateur-de-soudage-invertec-v-270-s-9
?mi cer scuze pentru r?u rom?ni, dar utiliza?i Google Translate!
Editat de welder
https://www.tehnium-azi.ro/forums/topic/6142-unitatea-de-comand-lincoln-electric-v270-s/
Dear friend, please use english.
Google traduce prost din limba bulgara in limba romana.
Google traduce destul de bine into english.
Foloseste propozitii scurte, google translate intelege corect.
Am primit pm de la tine si pe forum valvol.ru
Lipsa timp pentru raspuns corect.
Intreaba si pe Valentin Volodin.
Eu nu am raspuns acum.
Tu vrei detaliu.
Acum, eu nu am pentru reparat, in atelier, aparat like this.
Bine ai venit pe acest forum!
Este forum bun.
Eu apreciez la tine efort folosire limba romana.
Emil.
Editat de em2007
Dear Colleague,
Detail you requested is shown in the following picture:
Resistor value is 11 ohms.
In fact, there are 3 resistors in parallel, each resistor with a nominal value of 33 ohms.
??????????? ???????? ????????????? 11 ??.
?? ????? ????, ???? 3 ?????????? ???????????, ?????? ???????? ? ????????? 33 ??.
Sorry for the late reply, but I had a birthday and a few burned out single phase welding inverters for emergency repairs. As you can see in the photo, i change the resistors (as according to em2007) and an operational amplifier U1. Unfortunately, there is no success. The control board still not working. No pulses to power modules, The display values is out of range and is not affecting from the current setting potentiometer! In the next days I will continue to research for another possible defects and problems.
*The 4.7k resistor between pin1 and pin4 of the LM358 now is at the solder side of the pcb.
???????? ??? ??????? ?????, ?? ? ???? ???? ???? ???????? ? ????????? ????????? ?????????? ????????? ?????????? ??? ????????-???????. ??? ????? ?? ????, ????? ????????? (? ???????????? ?? ?????? em2007) ? ???????????? ????????? U1. ? ????????? ???????? ?????? ??? ? ???? ?????????? ?? ????????. ????????? ??????? ????? ???, ????? ?? ??????? ?? ????????? ????? ? ?? ????????? ?? ???????? ???????????? ????????? ?????????? ????! ? ????????? ??? ? ???? ?????????? ?????? ? ??????? ??? ????????.
*4.7k ????? ????? ???1 ? ???4 ????????????? U1 ?????? ????????? ? ???????? ??????? ?????.
Editat de welder
Resistor R3 = 10 Ohms!
11 ohms (2 x 22 ohms) in this pcb reduces the welding current actual value with 10%. Example: display shows 100 A -> welding inverter working at 90 A. IC LMC7660 in the power supply has replaced, because she was faulty too. Now everything is all right.
