EVM boxe rusesti ?
bvm
 Best Off EVM Music Production 3 cai 15"
SPEAKER MODEL B154A19
Specifications
Nominal diameter 380mm / 15"
Rated Impedance 4 or 8 ohms
AES Continuous Pink Noise Power 700 W
Sensitivity 99.0 dB SPL 1w / 1m
Frequency Range 40Hz - 2.2kHz
MAX Recomm. Frequency 1.3 kHz
Efective Piston Diameter 330mm / 13.2 in
Voice Coil Winding Material Copper-clad aluminum
Voice Coil
Winding Depth 19mm / 0.75in
Voice Coil Diameter 100mm / 4"
Magnetic Gap Depth 8mm / 0.317in
Magnetic Assembly
Weight 7.7 kg / 17 lbs
Flux Density 1.3 T
Bl Factor 20.1 T*m
Effective Moving Mass 0.098 kg
Thiele-Small Parameters
Free Air Resonanace (Fs) 35.0 Hz
D.C. Coil Resistance (Re) 3.4 (4) ohms / 6.0 (8) ohms
Total Quality Factor (Qts) 0.30
Mechanical Losses (Qms) 6.0
Electrical Losses (Qes) 0.32
Equivalent Volume of Air (Vas) 250.0 Liters
Effective Pistone Area (Sd) 895 sq.cm
Excursion (Xmax) +/- 5.5 mm
Max. Power Rating (Pe) 450W RMS sine wave
Inductance of V.C. (Le)
Efficiency (No) 3.23%
Mounting Information
Overall Diameter 390mm / 15.35 in
Overall Depth 142mm / 5.6 in
Bolt Circle Diameter 372mm / 14.65 in
Baffle Cuotour Diameter
Front Mount 355 mm / 13.97 in
Rear Mount 347mm / 13.65 in
Net Weight 10.65 kg / 25.0 lbs
Shipping Weight 11.85 kg / 26 lbs
Sa achizitionez asa ceva sau sa ma indrept catre altceva gen EV , etc.
Multumesc in avans pt pareri .
Editat de bvm
Ai cumva exact modelul asta?
53535663_2_1000x700_boxe-de-putere-best-
In boxele EV ai avut difurile originale sau au mai fost schimbate?
In locul celor originale de joase ar merge destul de bine un PAudio E15-600S (costa aprox.150Euro bucata):
http://www.paudiothailand.com/pdf/products/E15-600S1.pdf
Editat de leo_electro
De principiu as fi interesat sa achizitionez boxele pe care dvs le-ati postat , am discutat cu proprietarul dar nu a putut sa-mi dea prea multe informatii .
Doresc sa acizitionez ceva care sa poata fi folosite la auditie in casa cit si la petreceri .
