Cleste Ampermetric
kiru_tu
Cleste ampermetric LEM PR-30 250ron cu transport inclus
NOU variaza intre 100? si 330$, cel putin asa am gasit eu
Cleste ampermetric cu conectare directa la osciloscop
Stare aproape nou (9.9 din 10) nefolosit
O singura ?problema? daca se poate numi asa: s-a uitat bateria in interior si nu a fost folosit ceva vreme. A atacat/corodat foarte usor/putin conectorul de baterie doar atat.
http://www.tequipmen...t/LEMPR200.html
Electrical Characteristics
Current Range 20 A ACRMS or DC
Measuring Range ? 30 A
Output Sensitivity 100 mV / A
Accuracy (at +25?C) ? 1% of reading ? 2 mA
Resolution ? 1 mA
Load Impedance > 100 kOhms
Conductor Position Sensitivity ? 1% relative to centre reading
Frequency Range DC to 100 kHz (- 0.5 dB)
Phase Shift below 1 kHz < 2 degrees
Temperature Coefficient ? 0.01% of reading / ?C
Power Supply 9 V Alkaline, MN1604/PP3
30 Hours, low battery indicator
Working Voltage (see Safety Standards section) 300 V ACRMS or DC
General Characteristics
Maximum Conductor Size 19 mm diameter
Output Connection safety BNC connector
Output Zero Manual adjust via thumbwheel
Cable Length 2 meters
Operating Temperature Range 0 to +50 ?C
Storage Temperature Range (with battery removed) -20 to +85 ?C
Operating Humidity 15% to 85% (non condensing)
Weight 250 g
Poze reale:
http://i45.tinypic.com/2i7a8lf.jpg http://i48.tinypic.com/wchlyq.jpg http://i50.tinypic.com/11qizwo.jpg http://i49.tinypic.com/1z1chmb.jpg http://i49.tinypic.com/294nupv.jpg http://i50.tinypic.com/2ngc3cw.jpg http://i47.tinypic.com/347e3hd.jpg http://i45.tinypic.com/2wcidfp.jpg http://i47.tinypic.com/plule.jpg http://i47.tinypic.com/1ela4j.jpg
Perfect functional
Yd kiru_tu
Editat de kiru_tu
  • 3 months later...
