Intrare balansata si nebalansata
Dl. SIG, cablurile respective nu transforma un semnal nebalansat intr-un semnal balansat. Acele cabluri fac doar o adaptare care consta de fapt in conectarea "-" sau "+" a conectorului XLR la masa. Pentru semnal de la RCA se utilizeaza doar "+" si GND, cu "-" conectat tot la GND sau "-" si GND, cu "+" conectat tot la GND.
Daca doriti sa transformati semnalul nebalansat in semnal balansat puteti utiliza un circuit de genul acesta:
Unbalanced_Balanced_Converter.pdf
https://www.tehnium-azi.ro/forums/topic/478-intrare-balansata-si-nebalansata/page/2/#findComment-9257
  • 4 years later...
Dat fiind ca mi-a picat in mana o explicatie clara a modului cum este utilizat semnalul balansat, consider ca ii va lamuri/ajuta pe multi incepatori si ca atare o reproduc:
A balanced system is used in pro audio with an overall screen covering a twisted pair. Pin 2 on the XLR (nota: este vorba de XLR tata) is 'hot' and carries the positive going signal, whilst pin 3 is 'cold' and provides the return. Any interference that penetrates the overall braided screen affects both the 'hot' and 'cold' wires simultaneously, and due to the balanced transformer or electronics at the pre-amplifier is effectively ignored as the pre-amp only amplifies the difference between 'hot' and 'cold'. The female XLR uses the same pin numbering but pins 1 and 2 are reversed .
https://www.tehnium-azi.ro/forums/topic/478-intrare-balansata-si-nebalansata/page/2/#findComment-44138
