Ajutor modificare asm,
Buna ziua.
Am urmatorul asm si doresc sa schimb intrarea: RB0 cu RB6 .
Unde trebuie sa mai modific in afara de: BSF PORTB,0 ; !!Bank!! PORTB - TRISB - PORTB - TRISB
Am schimbat cu : BSF PORTB,6 ; !!Bank!! PORTB - TRISB - PORTB - TRISB
dar mai trebuie undeva. Unde?.
Multumesc.
Editat de ata
https://www.tehnium-azi.ro/forums/topic/4716-ajutor-modificare-asm/
codul sursa e in alt thread?
ca un sfat pentru viitor
definesti din capul locului
#DEFINE iesirea_mea PORTB,7
si peste tot in cod scrii
//pentru a seta bitul
bsf iesirea_mea
//pentru a sterge bitul
bcf iesirea_mea
astfel daca schimbi pozitia bitului la inceput nu trebuie sa modifci 200 de linii pe care trebuie sa le cauti cu lupa prin cod.
https://www.tehnium-azi.ro/forums/topic/4716-ajutor-modificare-asm/#findComment-43120
Am modificat asa:
LRAM_0x7B equ 0x7B
LRAM_0x7C equ 0x7C
LRAM_0x7D equ 0x7D
LRAM_0x7E equ 0x7E
LRAM_0x7F equ 0x7F
#Define pickup PORTB,7 ; adaugat
; Program
Org 0x0000
; Reset-Vector
GOTO LADR_0x000A
Org 0x0004
; Interrupt-Vector
MOVWF LRAM_0x7E
MOVF STATUS,W
MOVWF LRAM_0x70
MOVF LRAM_0x0A,W
MOVWF LRAM_0x71
GOTO LADR_0x0658
LADR_0x000A
GOTO LADR_0x062F
Org 0x0100
MOVWF LRAM_0x7F
MOVLW 0x01 ; b'00000001' d'001'
MOVWF LRAM_0x0A
MOVF LRAM_0x7F,W
ADDWF PCL,F ; !!Program-Counter-Modification
LADR_0x0105
GOTO LADR_0x0105
GOTO LADR_0x0644
LADR_0x0107
CLRF LRAM_0x58
CLRF LRAM_0x59
CLRF LRAM_0x57
CLRF LRAM_0x68
MOVLW 0x07 ; b'00000111' d'007'
MOVWF LRAM_0x1F
BSF STATUS,RP0 ; !!Bank Register-Bank(0/1)-Select
BCF LRAM_0x1F,7
BCF LRAM_0x1F,6
BCF PORTA,0 ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
BSF PORTA,1 ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
BCF PORTA,2 ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
BCF PORTA,3 ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
BCF PORTA,4 ; !!Bank!! PORTA - TRISA - Unimplemented - Unimplemented
BSF PORTB,7 ; !!Bank!! PORTB - TRISB - PORTB - TRISB - 6 mutat pe 13 -pickup
BCF PORTB,3 ; !!Bank!! PORTB - TRISB - PORTB - TRISB - 9 -30Khz-???
BCF PORTB,4 ; !!Bank!! PORTB - TRISB - PORTB - TRISB - 10-Output Scr-Igbt
BCF PORTB,5 ; !!Bank!! PORTB - TRISB - PORTB - TRISB - 11-Led
BSF pickup ; adaugat
CALL LADR_0x0692
Este bine?
https://www.tehnium-azi.ro/forums/topic/4716-ajutor-modificare-asm/#findComment-43124
http://www.electroni...coot/index.html
Aprindere electronica cu avans variabil.
Deschis pin 10 =are tensiune pe el 5v si trebuie sa aiba doar daca am semnal pe pin 13, RB7
Nu au importanta comenturile ex:
#DEFINE table PORTB,7 ; [pin13]= map selecting
#DEFINE rotor PORTB,4 ; [pin10]= sensor input
#DEFINE coil PORTB,2 ; [pin8]= output to coil
#DEFINE revcoil PORTA,3 ; [pin2]= reverse output to coil
#DEFINE rpmmax PORTA,2 ; [pin1]= Min and Max RPM led
#DEFINE led PORTB,6 ; [pin12]= pickup led
Editat de ata
https://www.tehnium-azi.ro/forums/topic/4716-ajutor-modificare-asm/#findComment-43129
probail ca nu au la asamblorul de pic, dar au la restul de 99% de ARM. Atmel, Intel, AMD etc. cat si la aproape toate compilatoarele de C.
nu pot sa-mi dau seama daca spftul tau e bun sau nu, pentru simplul fapt ca nu am timp sa ma uit prin el cum functioneaza.
bafta, si mult success
https://www.tehnium-azi.ro/forums/topic/4716-ajutor-modificare-asm/#findComment-43135
