1. Penseta EREM (SWISS made) un produs exceptional pt electronistii care lucreaza cu componente SMD, o astfel de penseta poate tine ani buni daca este utilizata cu grija am 2 bucati pretul pe bucata este de 60 ron.
# Stainless steel
# Anti-magnetic
# Super-fine points
# For handling very fine wires, miniature components
2. 95 Condensatoare Panasonic 100?F/35V
Descriere
* CAPACITOR, 100UF, 35V
* Capacitor Dielectric Type:Aluminium Electrolytic
* Capacitance:100?F
* Capacitance Tolerance:? 20%
* Voltage Rating:35V DC
* Series:AM
* Life Time @ Temperature:2000 hours @ 85?C
* Height:11.2mm
* Outer Diameter:6.3mm
* Capacitor Case Style:Radial Leaded
* No. of Pins:2
* Mounting Type:Through Hole
* Lead Spacing:2.5mm
* Operating Temperature Range:-40?C to +85?C
* SVHC:No SVHC (18-Jun-2010)
* AC Ripple Current:210mA
* Applications:Audio
* Body Diameter:6.3mm
* Operating Lifetime:2000h
* Operating Temperature Max:85?C
* Package / Case:Radial
* Temperature Operating Min:-40?C
* Terminal Type:Radial Leaded
* Tolerance +:20%
* Tolerance -:20%
* Voltage DC:35V
pret 50 ron toate 95
3. 10 Amplificatoare operationale FET OPA2132PA Texas Instruments - 12 ron/buc sau 100 ron toate 10.
* OP AMP, DUAL FET I/P, 2132, PDIP8
* Op Amp Type:High Speed
* No. of Amplifiers:2
* Bandwidth:8MHz
* Slew Rate:20V/?s
* Supply Voltage Range:? 2.5V to ? 18V
* Amplifier Case Style: DIP
* No. of Pins:8
* Operating Temperature Range:-55?C to +125?C
* LOW NOISE: 8nV/?Hz (1kHz)
* LOW DISTORTION: 0.00008%
* Package / Case:PDIP
* Amplifier Iype:FET Operational
* Base Number:2132
* Gain Bandwidth:8MHz
* IC Generic Number:2132
* Input Offset Voltage Max:2mV
* Operating Temperature Max:125?C
* Slew Rate:20V/?s
* Supply Voltage + Nom:15V
* Supply Voltage Max:18V
* Supply Voltage Min:2.5V
* Temperature Operating Min:-55?C
* Termination Type:Through Hole
4. Controller SATA ARECA ARC1110, PCI-X, compatibil PCI, 4 SATA, dupa cum se stie ARECA face cele mai performante controllere, stie RAID 0, 1, 1E, 3, 5, 6, cache 256MB, functioneaza fara probleme si in windows 7 - 120 ron.
5. Controller SCSI U320 ICP RAID Vortex GDT8114RZ, PCI-X, compatibil PCI, pe 68 pin, vine impreuna cu cablu pentru 3 device-uri si terminator, stie RAID 0 si 1, cache 128MB, functioneaza fara probleme si in windows 7 - 100 ron.
6. Controller SCSI U320 LSI20320-HP, PCI-X compatibil PCI, pe 68 pin, vine impreuna cu cablu pentru 3 device-uri si terminator, are ultimul firmware existent pe site-ul LSI, functioneaza fara probleme si in windows 7 - 100 ron.
7. Controller SCSI U160 Adaptec 29160N, PCI, 68 pin, vine impreuna cu cablu pentru 4 device-uri si terminator - 30 ron.
8. Controller SCSI Initio INIC-1060P PCI, 68 pin - 20 ron.
9. Controller ABIT HA66 PCI la 2 porturi IDE Ultra ATA 66 , vine impreuna cu cabluri - 30 ron
10. 2 module RDRAM Samsung MR16R0824BN1-CK8 de 64MB, 800MHz, nu cunosc starea lor si nu am pe ce sa le incerc, sunt de acord sa le trimit inainte (la useri seriosi) cu plata dupa - 30 ron/bucata in cazul in care sunt functionale.
11. Ventilator Delta FFB0812EHE este dintr-un server IBM deci a fost folosit o perioada dar functioneaza si arata impecabil, cine il cumpara primeste ca bonus sleeving si heatshrink necesar pt modarea lui :) - 50 ron
Model:FFB0812EHE
Physical dimensions:80x80x38mm
Operating voltage:7.0 - 13.8Vdc
Speed:5700RPM
CFM:80.16
Maximum Air Pressure:20.63mmH2O
Noise:52.5dB
12. 2xVentilator Nidec Beta V VA225DC au venit ca spare parts pt un server HP, nu au fost folosite, pret 30 ron/bucata sau 50 ron ambele
Model:VA225DC
Physical dimensions:60x60x38mm
Speed:8800RPM
CFM:50
Noise:56.7dB
13. HDD SCSI Fujitsu MAU3073NP 73GB, 15000 rpm 8MB, 68pin - pret 100ron
14. 3 buc HDD Toshiba MK2006GAL 20GB, 2MB Buffer, 4200rpm, ATA compliant, 1.8 inch
Pret 60 lei/buc.
Datasheet.
Atasat poze cu ele si starea fiecaruia in HD Tune
S/N 56096651W, S/N 45910221M, S/N N35S14983M
img7051u.th.jpg img7052n.th.jpg img7059k.th.jpg 23april20121757.th.png 23april20121751.th.png 23april20121750.th.png 23april20121833.th.png 23april20121832.th.png 23april20121831.th.png 23april20121802.th.png 23april20121801.th.png 23april20121800.th.png
15. HDD VelociRaptor WD3000HLFS 16MB 10000rpm pret 350lei sau schimb
img7596l.th.jpg 17august20121244.th.png 17august20121144.th.png velociraptorcumlamcumpa.th.png
Am atasat print screen-uri in HD Tune, warning-ul de la Ultra DMA CRC Error a fost urmarit timp, valoarea nu a crescut (exact cu aceeasi valoare a fost cumparat) cel mai probabil a aparut din cauza unui cablu/conector SATA defect.
Am atasat de asemenea si print screen din HD Tune in momentul in care a fost cumparat.
Ca si schimb doresc un amplificator audio pt casa, de calitate, min 2*50W, nu refuz amplificatoare vintage dar am pretentia sa nu fi fost umblate in ele, schimbate componente etc.
Prefer schimb in Timisoara.
16. Sleeving Braid NEGRU cu insertie de ALB, diametru 3mm, ideal pt. lucrare fir cu fir, un colac de ~50m pret 150ron/rola.
17. Sleeving Braid VERDE, GALBEN, ROSU, ALBASTRU diametru 3mm, la colac de 10m pret 50 ron
18. Culorile de mai sus le am si in versiunea ~10mm ideal pt cablurile SATA, un colac de 10m pret 80 ron
Mentionez ca sleeve-ul nu este chinezesc sau mai stiu ce facatura, este cumparat din Germania din magazin de specialitate.
19. Relee CP1SA-12V, montare pe suprafata PCB-ului (tipul 2 din datasheet), bobina la 12V, 2 contacte unul normal inchis si unul normal deschis.
Am 15 bucati, sigilate in folie, 8 lei/bucata sau 100 lei toate 15
Datasheet
20. Transformatoare ridicatoare tensiune SGE2685-1 pt. display-ul de pe borduri de Audi A6, Q7. Posibil sa se poata folosi si la alte display-uri.
Pret 50 lei/bucata, am cateva bucati.
Exemplu
Datasheet pt SGE2685-1G (e asemanator)
21. Relee NAIS ACT212 M47 12V, sunt relee duble cu cate 2 contacte unul normal deschis si unul normal inchis - pret 10 lei/buc
Datasheet
22. Tranzistoare MOSFET IRLR024N 55V, 17A, in capsula D-Pak pret 2 lei/buc.
Datasheet
23. CI TLE4267 5V Low Drop Voltage Regulator, in capsula PG-TO263-7-1 pret 4 lei/buc
Datasheet
24. 2 Tranzistoare CSD16404Q5A Power MOSFET N-CHANNEL folosite pe placi video seria 4870 (posibil si pe alimentare la diverse), am luat 4 bucati pt o placa Saphire 4870 si au fost folosite decat 2 - 40 ron ambele.
Datasheet
25. Tranzistoare NTD18N06LT4G Power MOSFET 18 Amps, 60 Volts N?Channel DPAK ON SEMI pret 4 lei/buc
Datasheet
26. Tranzistoare MJD42CT4, PNP, 100V, 6A, ON SEMI pret 3 lei/buc
Datasheet
27. Tranzistoare SI3459DV MOSFET P-Channel pret 3 lei/buc
Datasheet
28. Tranzistoare NTD3055, Power MOSFET 12 Amps, 60 Volts N-Channel DPAK, ON SEMI pret 4 lei/buc
Datasheet
29. Tranzistoare BCP51, PNP, pret 0,5 lei/buc
Datasheet
30. Tranzistoare BCP55, NPN, pret 0,5 lei/buc
Datasheet
31. CI LM2904M DUAL OPAMP, pret 2 lei/buc
Datasheet
32. CI A82C250 CAN Interface, pret 2lei/buc
Datasheet
33. Condensatoare electrolitice Nippon Chemi-Con 8100uF/35V - 6lei/buc si 6800uF - 5lei/buc
34. CI FM25640 RAMTRON - FRAM, 64K, SPI, 8SOIC pret 10lei/buc
Datasheet
35. Tranzistor FZT651 - NPN, 60V, 3A, SOT-223 pret 3lei/buc
Datasheet
36. Quartz 32.768000 kHz - SMD pret 3lei/buc
37. Condensatoare Tantal, capsula SMD, pret 1 leu/buc
-1uF/16V
-3,3uF/16V
-10uF/16V
-15uF/10V
-15uF/16V
-22uF/35V
-33uF/16V
-33uF/20V
-47uF/6,3V
38. Microintrerupatoare, SMD, pret 1,5 lei/buc
39. CI ATMEGA8515-16AU, 6 bucati disponibile, pret 7 lei/buc
Datasheet
40. CI MAX7301AAX, 10 bucati disponibile, pret 15 lei/buc
Datasheet
41. CI ULN2803A, 20 bucati disponibile, pret 1 leu/buc
Datasheet
42. Tranzistoare BUK765R2-40B N-channel TrenchMOS standard level FET in capsula D2PAK, 40V 75A, disponibile 40 bucati, pret 7 lei/buc.
Datasheet
43. Tranzistoare BCP53 PNP for audio, pret 0,5 lei/buc.
Datasheet
44. Motor pas cu pas SANYO DENKI 1.8DEG, 3.6V nou, o bucata disponibila, 70 lei
Datasheet
45. CI MAX9244EUM si MAX9246EUM 21-Bit Deserializers with Programmable Spread Spectrum and DC Balance pret 10lei/buc
Datasheet
46. Diode Schottky MBRB20100CT 100 V, 20 A pret 2 lei/buc
Datasheet
La care produse nu am specificat nr. de buc. inseamna ca sunt disponibile peste 20-30 buc., eventual intrebati sa va spun exact...
Livrare prin posta/curier la alegere. Daca se plateste in avans pe card transportul prin posta este gratuit.
Va rog comenzile sa fie de minim 30 lei.
Accept si schimburi cu LED-uri de putere.
Contact aici, PM, trif_florin_cheloo at yahoo dot com or trif.florin at gmail dot com
https://www.tehnium-azi.ro/forums/topic/4685-vand-urmatoarele-update-periodic/
