TRUCURI MICI.........EFECTE MARI!
Sau programul asta:
http://www.acoustica.com/mp3-audio-mixer/
Cu acest program aveti si facilitati de mixare, taiere a melodiilor cu posibilitatea de "fade-in sau out".
Utilitatea programelor recomandate este dovedita de numarul tot mai mare de download-uri. Am rugamintea ca programele si aplicatiile soft recomandate in diferitele topicuri din forum sa fie insotite, daca se poate, si de o scurta caracterizare ca in exemplul de mai sus si cu precizarea daca este free. Va multumesc!
https://www.tehnium-azi.ro/forums/topic/446-trucuri-miciefecte-mari/#findComment-3990
Incearca cu acest player & converter. Foobar2000
http://www.foobar2000.org/
Sau programul asta:
Receptionat ! Va multumesc mult !
https://www.tehnium-azi.ro/forums/topic/446-trucuri-miciefecte-mari/#findComment-4020
Daca aveti probleme cu webcam-ul in Yahoo Messenger,care se manifesta prin blocarea programului,la incercarea de a porni camera,incercati acesti pasi.
1. Log off and shut down Messenger.
2. From the Windows Start menu at the left bottom of your screen, click
"Run."
3. From the input area, type "regedit" (but not the quotation marks!)
and press "Enter." The registry editor application should open.
4. On the left side, expand the HKEY_CURRENT_USER folder (or key) by
clicking the plus (+) sign, then expand the Software folder under it,
then select "Yahoo"
5. If there is a Webcam folder, go to the next step. If there is no
Webcam below the Yahoo folder
- click on "Edit" from the menu
- select New then Key
- type "Webcam" without the quotation marks
6. Select the Webcam folder.
7. From the Edit menu click on New, DWORD Value, and type UseVFW
without any spaces.
8. Double-click on the entry UseVFW and change the entry in Value data
to 1. Then click "OK."
9. Now select the Pager folder
10. From the Edit menu click on New, DWORD Value, and type UseVFW
without any spaces.
11. Double-click on the entry UseVFW and change the entry in Value data
12. Exit the Registry Editor application.
13. Restart Yahoo! Messenger and try starting your webcam by clicking
"Start My Webcam" from the main window's Tools menu.
https://www.tehnium-azi.ro/forums/topic/446-trucuri-miciefecte-mari/#findComment-4022
