pentru cei care au hobby , receptia programelor TV codate in Nagra 3, va prezentam noutatile.
(in Engleza)
http://nagravisionthree.blogspot.com/
nu am reusit sa adaug atasamente, dpdv al marimii acestora, deci pentru studiu- mergeti aici
http://dreambox-clon...c.php?f=8&t=225
articolul este cu titlu informativ.
Nagravision Nagra 3 Bell Expressvu ROM 240 REV 900 Nagra Card
Is A 5V 8-Bit 6805 CISC Based Micro Controller @ 5Mhz With
Hard Coded MAP ROM And SYS ROMs, RAM And EEPROM
Covering Address Space $0000 To $FFFF = $64K. Most Generic
6805 Based Code Will Run On All Versions Of Nagravision 1, 2, & 3
Smart Card And iCAM Nagra3 Processors With Most Instructions
Processing Taking Somewhere Between 1 And 5 Clock Cycles.
It Has A Total Of 6x Manufacturer Known Security Holes And Exploits
That Have Been Patched Via Stream EEPROM Updates And 3 Known
Manufacturer Unknown / Unaware Holes That Span All Current And
Previous EEPROM Updates And Probably Contains More.
Nagravision Nagra 3 ROM 240 REV 900 Nagra Cards EEPROMs
Will Been Update 6x Times From REV 900 -> REV 901 -> REV 902
-> REV 903 -> REV 904 -> REV 905 -> REV 906 In The BEV Bell
Stream Without A Subscription And Closes A Known Security Hole
Vulnerability That Can Be Abused With A Basic Every Day ISO-7816
Smart Card Reader And A Nagra 3 ROM 240 REV 900 Smart Card.
To Completely Penetrate & Hack A Nagravision Nagra 3 ROM 240
Nagra Processor Based Smart Card Running EEPROM REV 900
We Need To Penetrate, Locate, Extract, Recover, Assemble,
Disassemble And Study The Used Portions Of Memory Address
Locations And Recover Code & Data Values From $0000-$FFFF.
More Specifically N3 Attackers Want Fast Easy Access To Both
The SYSROM & EEPROM For Smart Card Hacks And Total
Access To N3 ROM 240 MAPROM, SYSROM, AND EEPROM
For Long Term Permanent Smart Card System Based Emulation
Like Nagra 3 FTA, N3 DVB, And Smart Card Simulator Like
N3 Atmega 128 / Atmega 256.
pentru studiu
http://www.jameco.com/Jameco/catalogs/c121/p7.pdf
http://www.epanorama.net/links/microprocessor.html
Editat de strike_gabriel
https://www.tehnium-azi.ro/forums/topic/4430-nagra-3/
