Relee ?ntre 3 si 7 lei
http://i29.tinypic.com/2rf6giu.jpg
http://i28.tinypic.com/a1poiv.jpg
http://i27.tinypic.com/11h807b.jpg
http://i32.tinypic.com/azi100.jpg
http://i31.tinypic.com/ddhqq0.jpg
http://i25.tinypic.com/2vxozlx.jpg
http://i30.tinypic.com/10e0mkh.jpg
http://i27.tinypic.com/jgs7xz.jpg
http://i26.tinypic.com/3329sme.jpg
http://i31.tinypic.com/2el8cvq.jpg
http://i31.tinypic.com/2gy3fxz.jpg
http://i32.tinypic.com/2vrv7tt.jpg
http://i32.tinypic.com/2079md1.jpg
http://i32.tinypic.com/do6zhf.jpg
http://i27.tinypic.com/21b3sph.jpg
http://i25.tinypic.com/1ju2s0.jpg
http://i32.tinypic.com/jaynq1.jpg
http://i31.tinypic.com/r6zki9.jpg
http://i31.tinypic.com/n49oqt.jpg
http://i28.tinypic.com/whcep.jpg
http://i25.tinypic.com/2z3qnh0.jpg
http://i32.tinypic.com/sazabm.jpg
http://i32.tinypic.com/140hnd2.jpg
http://i25.tinypic.com/14y8gox.jpg
http://i30.tinypic.com/30nc9zo.jpg
http://i31.tinypic.com/33cmdqa.jpg
http://i32.tinypic.com/w1ec5t.jpg
http://i29.tinypic.com/30jmes7.jpg
http://i25.tinypic.com/2rmv3ap.jpg
http://i26.tinypic.com/2a5x4t5.jpg
http://i30.tinypic.com/2n7qeqa.jpg
http://i32.tinypic.com/mm4s45.jpg
http://i32.tinypic.com/2im87sg.jpg
http://i25.tinypic.com/9qai2x.jpg
http://i26.tinypic.com/2eft8x2.jpg
http://i25.tinypic.com/21mw9ys.jpg
http://i31.tinypic.com/35l4w01.jpg
http://i29.tinypic.com/34or7uq.jpg
http://i29.tinypic.com/rtdqid.jpg
http://i29.tinypic.com/2rho6xj.jpg
http://i32.tinypic.com/2mpbuqd.jpg
http://i27.tinypic.com/2v9pzjb.jpg
http://i25.tinypic.com/2csgn55.jpg
http://i31.tinypic.com/117qt12.jpg
http://i32.tinypic.com/anziah.jpg
http://i29.tinypic.com/nvbkea.jpg
http://i29.tinypic.com/20r0lc4.jpg
http://i30.tinypic.com/ejz8s4.jpg
http://i28.tinypic.com/200eejk.jpg
http://i26.tinypic.com/do8ghw.jpg
http://i28.tinypic.com/9j0rqo.jpg
http://i27.tinypic.com/11r3tdh.jpg
http://i27.tinypic.com/30agqop.jpg
http://i31.tinypic.com/dcvm6b.jpg
http://i28.tinypic.com/30m31tv.jpg
http://i25.tinypic.com/oaoz77.jpg
http://i25.tinypic.com/3538two.jpg
http://i32.tinypic.com/euq35h.jpg
http://i25.tinypic.com/25kh0fm.jpg
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/
Salutare;pe mine ma intereseaza un releu DPDT (double pole double throw ) cu suprafetele de contact la lamele ,mari
Ce am eu se sudeaza cind releul se activeaza din cauza energiei mari trimise prin ele.
Prin urmare ma intereseaza sa aiba contactele de pe lamelele fixe si mobile de cel putin citiva mm.(de la 4-5 mm in sus) si alimentat la 12 -24 volti..Ai asa ceva?
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29322
Acesta:http://i31.tinypic.com/33cmdqa.jpg,http://i32.tinypic.com/w1ec5t.jpg,http://i30.tinypic.com/30nc9zo.jpg
Are 5mm diametru contactelor Are trei perechi ND-NI, la 24 V Restul te rog sa ma lamuresti ca nu stiu ce inseamna sau poate si cred ca in alta denumire stiu deci ..lamuriri
Si mai e acesta:http://i26.tinypic.com/2a5x4t5.jpg
care are contactele de 4 mm diametru si are 4 ND-NI,24V
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29362
Banuiesc ca te referi le denumirea de DPDT ;uite aici o imagine in miscare http://www.kpsec.freeuk.com/components/relay.htm un pic mai jos in dreapta iti arata un releu DPDT-de mici dimensiuni.
Acum te rog sa ma lamureti tu ce inseamna 4 ND-NI de fapt ND NI nu pricep ce reprezinta...
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29386
ND= normal deschis
NI=normal inchis
Starea normale este considerata starea de repaus, nealimentat/actionat, cand nu circula curent prin bobina lui.
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29387
Acum ca domnu Miron m-a lamurit spune-mi te rog daca ai cu contacte mai mari .M-am uitat mai atent la releele mele si
diametrul contactelor e cam asemanator.Ca sa fiu sigur ca nu se sudeaza , cred ca ar fi bine sa aiba contacte de circa 1 cm daca exista relee asa de mari...
Intrebare pt domnul Miron;avind in vedere problemele cu care ma confrunt, credeti ca ar fi posibil sa folosesc contactele releului pentru a actiona un triac de exemplu pentru a face transferul energetic fara sa mai apara sudura contactelor?
Credeti ca rezista triacul la descarcarea unui condensator de 500-1000 micro 100-120 volti?
Ma gindeam ,oare ar fi posibila legarea in paralel a mai multor triace actionate simultan pentru a reduce ,imparti energia transferata prin ele?
Multumesc
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29389
Puteti, dar tot asa de bine puteti si cu un intrerupator.
Depinde de model, dar sigur aveti nevoie de triac si nu tiristor?Daca este curent continu, nu va trebuie triac, iar tirstori sunt si pentru 500A.
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29391
Asa este ;un tiristor e mai indicat;multumesc pentru corectie;
Fiti amabil si spuneti-mi un magazin virtual unde pot sa imi aleg tiristorii de care am nevoie (cu valori mari pentru amperajul suportat)
Iar referitor la intrerupatorul mentionat de dvs , la ce intrerupator v-ati gindit?;el trebuie sa fie actionat automat de un circuit electronic (eu folosesc 555) aferent ,periodic si nu manual...
Multumesc
Editat de sinergicus
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29414
Aici. Sper ca 350A sunt suficienti.
La ce interval?
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29416
La ce interval?
Referitor la timer ,am mai discutat asta cu dvs in alt topic,si mi-ati oferit o schema de 555 cu consum redus de curent cu raportul cuplare decuplare reglabil , de circa 0,5 secunde bobina releului cupplata ,la 4-5 secunde pauza. (schema clasica consuma 100 ma aproximativ)pe care o si folosesc;am reusit astfel sa reduc consumul inutil de la 100 ma la circa 15 ma ...multumiri inca o data
Mentionez ca iesirea timerului actioneaza baza unui tranzistor pentru a pune in miscare bratele releului...care in conditiile mentionate ,din pacate,se sudeaza.
Daca tot ati adus vorba, va rog sa imi spuneti o schema de oscilator (pe cit posibil cit mai simpla) care sa imi permita obtinerea unei freqvente de circa 600 khz...schema de baza folosea o sirena actionata de un motor pentru a pune in oscilatie un lichid dintr-un container ,la aceasta freqventa...eu ma gindeam sa folosesc un oscilator electronic care sa faca treaba asta.
555 se pare nu atinge aceasta freqventa;ar fi fost cel mai usor cu un timer clasic...
Multumesc
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29426
Daca utilizati tiristorul de 350A nu mai aveti problema aceasta.
Aici nu inteleg cum agita o sirena lichidul?Poate imi dati mai multe date.
Oscillatorul se comanda?
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29429
Aveti in pdf attasat schema si explicatii cu privire la dispozitiv
Am luat schema dintr-unul din documentele de pe aceasta pagina
http://www.free-energy-info.co.uk/
Am pus linkul deoarece sint multe informatii pe care eu le consider interesante;poate mai e si altcineva interesat de acest gen de informatii
Distiled water generator.pdf
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29430
Probabil este o sirena speciala(rotor cu multe pale/fante si turatie ff.mare) daca poate produce ultrasunete. Pentru traductorul utrasonor, eu cred ca mai intai ar trebui sa-l aveti, pentru a putea corela posibilitatile oscilatorului, cu tensiunea si curentul necesar acestuia pentru a functiona.Un oscilator de 600KHz nu este o mare problema, dar etajul de putere dintre el si traductor, poate fi.
https://www.tehnium-azi.ro/forums/topic/3193-vind-relee-diverse-de-la-5v-24v/#findComment-29432
