Va salut,
As dori sa stiu cum pot initializa un hard disc? In DISC MANAGEMENT imi apare: Disk0 Unknow, Not Initialized, dupa aceea capacitatea si sub capacitate imi scrie Unallocated.
Deci.... va rog....!
Toate cele bune
dan
Editat de dan_e
https://www.tehnium-azi.ro/forums/topic/2549-cum-pot-initializa-un-hard-disc/
"Under Disk Management, on the bottom pane, scroll down until you see your new disk listed. It should display something like "not initialized". Right click and select to initialize or format the disk. From there you can follow the prompts."
Daca hardul este nou, acesta va trebui formatat pentru a putea fi folosit.
https://www.tehnium-azi.ro/forums/topic/2549-cum-pot-initializa-un-hard-disc/#findComment-23199
