ajutor subwoofer
denka
Salutare !
am facut rost de un dif SPECTRON SPC 1200 GT care arata bine si as vrea sa imi fac un subwoofer din el.
numai ca eu si cu winisd-ul nu ne prea intelegem!
as avea o rugaminte: daca poate sa simuleze cineva care se pricepe o incinta?
Specificatii : "doar asta am gasit" :
KEY FEATURES SPC1200GT WOOFER
? Diamond-Cut Aluminum Cast Basket
? Crosswoven Carbon Fiber Cone
? 2? Black Aluminum Voice-Coil Former
? Black Dual Spiders
? Extended Center Pole
? Backvented Cavity
? Butyl Rubber Surround
? 2 x 50 oz. Ceramic Magnet
? 4-Layer Wound Voice-Coil
? 10 mm Front Pole Plate
? Rubber Gasket
? Isolated Screw-Terminals
SPECIFICATIONS
SPC1200GT
Frequency Response - 20 - 200 Hz*
Continuous Power Handling - 500 Watts*
Peak Power Handling - 650 Watts*
Nominal Impedance - 4 Ohms
Voice-Coil Diameter - 50 mm
*Depending on enclosure type and volume!
THIELE / SMALL PARAMETERS
SPC1200GT
Free-Air Resonance Frequency (Fs) - 25.2 Hz
DC Resistance of Voice-Coil (Re) - 3.2 Ohm
Electro-Magnetic Q (Qes) - 0.35
Mechanical Q (Qms) - 4.30
Total Q (Qts) - 0.32
Suspension Stiffness (Vas) - 70.1 l
Moving Mass incl. Air-Load (Mms) - 190.0 g
Peak Linear Displacement of Diaphragm (Xmax) - 10.0 mm
Acoustically Effective Cone Surface (Sd) - 478 cm2
Peak Displacement Volume (Vd) - 960 cm3
Sensitivity @ 2.83V/1m (SPLref) -87.0 dB
MOUNTING DIMENSIONS
SPC1200GT
Woofer Monting Cut-Out - 282 mm
Woofer Mounting Depth - 168 mm
Si ceva poze:
http://i40.tinypic.com/swzewg.jpg
http://i40.tinypic.com/er0mzq.jpg
http://i41.tinypic.com/znr5op.jpg
WinISD zice ca cel mai bine se comporta intr-o boxa, bas reflex, cu volum net Vb = 34 L.
La acest volum dat se obtine F3 = 37 hz, Fb = 25 Hz, in conditiile unui port de anumite dimensiuni.
Intrucat un port rotund trebuia sa aiba o lungime destul de mare, ar fi bine de executat un port tip fanta, cu labirint. (vezi poza).
Portul ar trebui sa aiba deschiderea fantei de 30 x 4 cm sa zicem, si lungimea de 161 cm . Datorita faptului ca nici o suprafata a boxei nu va fi atat de lunga (161 cm), se rezolva prin acel labirint de care pomeneam.
Daca se porneste de la o boxa, sa zicem, cu dimensiuni de 47 cm x 47 cm x 30 cm, daca i se calculeaza volumul exterior si daca i se scad volumul partilor componente (difuzor, placile de PAL/MDF, placile care formeaza portul, o ramforsare suplimentara de exemplu daca e cazul), ar trebui sa ramana un volum net apropiat celui cerut (34 L). (poti face calcule mai exacte, e geometrie simpla). Calculul este iterativ si trebuie facute mai multe incercari. (sau daca ai un program specializate de calculat incinte iti iese in prima)
Aerul circula prin fanta conform liniei rosii punctate.
Este doar un exemplu de boxa bas reflex, poti face una trapezoidala daca vrei.
Succes.
Editat de SIG
