VAND DIVERSE PIESE SI OSCILOSCOP HP
Vizitator tedexy
Vizitator tedexy
Salut, am de vanzare si eu vreo 2 cutii de piese , in principal circuite integrate, trafo linii, trec mai jos un mic sumar, daca e cineva interesat... in principal dintre cei care se ocupa cu depanarea, vreau sa le dau pe toate la un pret bun
piesele sunt:
TDA8362B - vreo 30 buc
GS8434-01C - 13 buc
CF72306 - 6 buc
GS8334-02B- vreo 43 buc
TDA8395 - 33 BUC
TDA8196 - 6 BUC
CF70200NW- 6 BUC
TDA4661-30 BUC
AN5860-6 BUC
TDA8395-6 BUC
DIVERSI CONDENSATORI, ELECTROLITICI SI NU NUMAI , CHOPPERE LINII FARA NUMAR, INTRERUPATOARE RETEA
LA7833
AN5633
PCA84C640P/030
TDA2006 - F MULTE
GL7805
QUARTZ0URI DE 10000
TRAFO LINII - GOLDSTAR , INDICATIV - 154-177 - APROX 50 BUCATI
CHOPPER SURSA GOLDSTAR - iNDICATIV 151-479A
si mai sunt multe...... dar nu am ampucat decat sa fac un scurt inventar la o cutie, vreau sa vad daca este cineva interesat
ms
si un osciloscop HP de 100 Mhz, cu 3 sonde, functioneaza ireprosabil
caracteristici : Hp 108 A
100 MHz Mainframe. Usually comes with 1801A Dual-Trace 50 MHz Vertical Amplifier and 1820A Time Base Plug-ins: Solid State general-purpose laboratory or service bench scope. Full-up, solid performing. All discrete circuitry, no special and unavailable IC's. Hp also made Spectrum Analyzer plug-ins for this scope. Viewing area 8x10 cm.
FEATURES:
o Dual Trace with Chop and Alternating Trace Modes
o Internal Graticule No-parallax CRT
o Calibrated sensitivity and sweep ranges
o Beam Finder
o Scale Illumination Control
o Automatic Triggering
o 5x and 10x Sweep Expand
o Internal Calibrator
o Outputs: Main and Delayed Gates, Main and Delayed Sweeps
SPECIFICATIONS:
1801A 50 MHz VERTICAL AMPLIFIER:
5 Modes: Channel A alone, B alone, A & B Alt, Chop with blanking, A + B
Bandwidth: DC to 50 MHz
Sensitivity: 5 mV/cm to 20V/cm, in 12 calibrated positions with 1,2,5 sequence
Attenuator Accuracy: +/-3dB.
Rise-Time less than 7 ns
Input Impedance: 1Mohm shunted by 25 pf
Triggering; A, B, A+B modes, dc to 50 MHz
1821A TIME BASE AND DELAY GENERATOR
Time Base Sweep: 0/05 uS/cm to 2sec/cm
Triggering dc to 50 MHz
Triggering Modes: Int, Ext, Line
Sweep Modes: Auto, Normal, Single
Display Modes: Main, Mixed, Delayed
181AR MAINFRAME
Calibrator: 1 kHz Square Wave, 3uS rise time
CRT Accelerating Potential: 12KV.
CRT: P31 Phospher
CRT Internal Graticule: 8x10 cm, 2mm subdivisions
Power Requirements: 115 or 230 VAC 50/60Hz, 110 Watts
Weight: 32 lbs, Shipping Wt: 44 lbs
http://tinypic.com/r/2v9sw7m/3
pret 300 RON
Editat de tedexy
Vizitator tedexy
UPPPPPPPP 250 RON, hai ca vreau sa scap din casa de el
piesele sunt:
GS8434-01C - 13 buc
CF72306 - 6 buc
TDA8395 - 33 BUC
TDA8196 - 6 BUC
CF70200NW- 6 BUC
TDA4661-30 BUC
AN5860-6 BUC
TDA8395-6 BUC
LA7833
AN5633
PCA84C640P/030
TDA2006 - F MULTE
GL7805
QUARTZ0URI DE 10000
ms
FEATURES:
o Beam Finder
SPECIFICATIONS:
181AR MAINFRAME
CRT: P31 Phospher
pret 300 RON
Salut!mai este de actualitate?lasa si tu un nr de telefon,ceva!te contactez eu.sunt interesat de mai multe
Vizitator alxxx
Va salut. Sunt interesat de osciloscop si va rog sa-mi spuneti daca il mai aveti.
O zi buna.
Vizitator alxxx
piesele sunt:
GS8434-01C - 13 buc
CF72306 - 6 buc
TDA8395 - 33 BUC
TDA8196 - 6 BUC
CF70200NW- 6 BUC
TDA4661-30 BUC
AN5860-6 BUC
TDA8395-6 BUC
LA7833
AN5633
PCA84C640P/030
TDA2006 - F MULTE
GL7805
QUARTZ0URI DE 10000
ms
FEATURES:
o Beam Finder
SPECIFICATIONS:
181AR MAINFRAME
CRT: P31 Phospher
pret 300 RON
O zi buna.
  • 4 weeks later...
  • 3 months later...
Vizitator tedexy
scuze ca nu am raspuns... revin piesele la vanzare, oscilo nu mai este.... pentru piese , se face un pret bun pentru toate, sau o parte , o sa caut insa pt user-ul alex66 ci-urile
