Vand placa de baza ASUS VIA KT880
donpetru
A7V880 ASUS VIA KT880 + VT8237, Sk A, FSB400Mhz, 4*DDR400dual channel, 1*AGP8x/6*PCI, 6ch Audio, Lan Gigabit Marvell, USB2.0, RAID 0 or 1 S-ATA * 2 ports, full ATX
CPU Socket:
A
Chipset:
VIA KT880
VIA VT8237
FSB (MHz) - max:
400 MHz
Bios:
4Mb Flash ROM, Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, ACPI, ASUS EZ Flash, CrashFree BIOS 2, C.P.R., MyLogo
Procesor / Memorie
Procesoare compatibile:
Socket A for AMD Athlon XP
Thoroughbred / Barton Core support
Numar procesoare suportate:
1
Tehnolgie RAM suportata:
Dual Channel Memory Architecture
- 4 x 184-pin DIMM Sockets
non-ECC DDR SDRAM memory
Tehnolgie RAM:
PC3200/PC2700/PC2100
RAM instalat (max):
4GB
Caracteristici Audio
Audio:
ADI SoundMAX 6-channel audio CODEC
Support S/PDIF out Interface
Canale audio:
5.1
Body & Design
Tip Carcasa:
ATX
Expansiune/ Conectivitate
Sloturi disponibile:
1 x AGP 8X
5 x PCI
1 x ASUS Wi-Fi slot for Wireless LAN upgrade
Interfete:
1 x Parallel
1 x Serial
1 x PS/2 Keyboard
1 x PS/2 Mouse
1 x Audio I/O
1 x SPDIF out
1 x RJ45
4 x USB 2
Retea:
Marvell Gigabit LAN controller supporting 10/100/1000 BASE-T Ethernet
Tip controller:
IDE - integrat - PCI
Altele
Caracteristici:
Internal I/O Connectors:
- 2 x USB 2.0 connector support additional 4 USB 2.0 ports
- CPU / Chassis FAN connectors
- Chassis Intrusion
- 20-pin ATX Power connector
- S/PDIF out Interface
- CD/AUX audio in
- Game/MIDI port connector
- 20 Pin Panel connector
- Front Panel Audio connector
Dotari:
Support CD:
- Drivers
Pret de licitatie: 90lei
