Osciloscop
Osciloscolpul pe PC poate fi solutia econimica pt. un electronist, singurul element care trebuie realizat fiind interfata cu calculatorul, restul e software. O singura mare problema trebuie avuta in vedere daca se opteaza pt. asa ceva, si anume protectia portului pe care se realizeaza interfatarea. Montajul ar trebui sa fie izolat fata de port (buffere, optocuploare, etc.) si bine verificat inainte de a fi conectat. "Prajirea" portul din cauza "osciloscopului" ar putea fi extrem de "amuzanta" pt. fericitul posesor al aparatului.
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-1741
  • 2 months later...
  • 5 months later...
  • 4 months later...
Asta este schema a osciloscopului PCS500 de la Vellman
Date tehnice:
inputs: 2 channels, 1 external trigger input
- input impedance : 1 Mohm / 30pF
- frequency response ?3dB: 0 Hz to 50 MHz
- maximum input voltage : 100V (AC + DC)
- input coupling : DC, AC and GND
- Optical ISOLATED from computer
- supply voltage : 9 - 10Vdc / 1000mA
In Romania costa cam 20.000.000 lei vechi
PCS500_9a_cir.pdf
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-13374
Un osciloscop pe portul paralel ,fara memorie interna ,care are o schema foarte simpla am preluoato cam de mult ,de la adresa de sait ,aici gasiti si soft cu o versiune free.
http://www.volny.cz-elecon-cz-lptoscilosko...ky-schema_gif_f
LPT oscilloscope
1. Introduction
For this constructions I was inspired LPTScope from Bojan Banko. I build a new hardware and modify software with permission from author.
This construction is free for personal use, for commercial use you need permission from author (from author original software too).
2.Technical statements
Supply voltage ~9 - 15V
Input voltage DC/AC (peak to peak) 0,2V; 0,5V; 1V; 2,5V; 5V; 25V
Max. input voltage 100V
Input resistance 1MW
Maximal sample rate theoretical 600kHz
practical 300kHz
Vertical shifting of zero -10% to +60% input range
Setting up of trigger 0 to 100% input range
Connection to PC bidirectional LPT port
3.Circuit
For A/D converter I use TLC0820 with protection resistors R1-R8. Input circuit created voltage divider 1:5 with switch PR1.
Switch PR3 set up zero for input and switch PR4 set up measure of AC/DC signal.
Input amplifier is created IO2A. Switch PR2 set up amplify 1:1, 10:1 and 25:1. Summary amplifier is created IO2B and shifting zero for measure AC signal.
Potentiometer P2 and IO2D set up trigger.
The oscilloscope use several stabilized DC voltages +5V (IO5), +9V (IO3), -9V (IO4).
4. Mechanical design
For construction is used one side PCB with several connection wires (layout chart of components). For oscilloscope is used box U-KM26, see figure 1 - 2 - 3.
5. Setting up
First you install supply part inclusive of K3. You check on voltage +5V, +9V, -9V. Now you install IO2 and all components except IO1 and check function. If it is all right, you can install IO1 and resistors R1-R8 (SMD).
You must set LPT1 on bidirectional or ECP or EPP in BIOS and then connect oscilloscope to LPT1 port PC.
6. Software LPTScope
Program is freeware, included source code.
If you connect hardware for the first time, you start measurement - pres button "Run". You should to see horizontal black line. Line have vertical shifting, when you turning potentiometer P1. When line not shifting, you must set regular reading from A/D converter (press button AD on toolbar) by means of set up number waiting cycles. You turning potentiometer P1 and look at voltmeter. You must see stable data and data must react to turning potentiometer. Regular reading you check up on to signal applied to input.
One record - activate measure, after buffer is full, measure be stoped
TRG INT - internal software trigger
TRG EXT - internal hardware trigger from input signal. You can modify hardware to external trigger
Violet line - shifting zero of input signal. When is negative shifting, negative voltage not display (it display as zero).
Use mouse - when you press left button, you can movie mouse and you will see voltage (Y axis) and time and frequency (X axis)
Time base - set scale on axis X
Y base - set scale on axis Y
Oscilloscope input correction - for right display input voltage (input range)
Sampling rate - setting up when set number waiting cycles for reading from A/D converter
Sample buffer - for saving data from A/D converter. Use max 10000 for oscilloscope and max 1000000 for One record mode
You can see max 32000 points on the screen. When sample buffer is bigger and you want to see whole buffer, you must set bigger Time base = 32000/(Sampling rate * Sample buffer).
Download LPTScope version 1.3
Download source code
7. Components list
Electrolytic capacitors
C1,C2 220 uF/25V
C3,C4,C6,C7 47 uF/16V
C5 100 uF/25V
C23 22uF/16V
Ceramic capacitors
C8, C9,C10,C11,C12,
C13,C14,C15,C16 100 nF
C18,C17 22 pF
C20 12 pF
C21 47 pF
Plastic capacitors
C19 100 nF/250V
C22 100 pF/250V
Diode
D2,D1 1N4005
D3,D4,D7 BAT48
D5,D6 1N4148
ZD1 BZX83V5,6V
ZD2,ZD3 BZX83V10
ZD4 BZX83V5V1
Integrated circuit
IO1 TLC0820
IO2 TL074
IO3 78L09
IO4 79L09
IO5 78L05
Connectors
K1 CAN25VP
K2 BNC-Z 50RW
K3 SCD-016
Inductors
L2,L1 220 uH
Switches
PR1,PR3,PR4 P-B143
PR2 P-GS373
Potentiometers PC 1221N
P2,P1 10k
Resistors SMD 1206
R1,R2,R3,R4,R5,R6,R7,R8 680
Resistors 0,4W
R9 1k
R10,R11 100k
R12 120k
R13 680k
R15,R20,R21,R22,
R23,R24,R25 4k7
R16 470
R17 56
R18 180
R19 15
R26,R30 10k
R27 15k
R28 22k
R29,R31,R33 10k
R32 8k2
Resistors 2W
R14 10k
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-13375
Vizitator crriss
poti sa uiti de schema asta, atata timp cat nu ai config file-ul pentu PAL. in plus schema are si cateva greseli evidente (mai mult sau mai putin intentionate)
pret aberant pentru complexitatea si performantele schemei, la banii astia cumperi un osciloscop semiprofesional second hand care nu se poate compara cu ariciul asta.
un proiect complet si foarte simplu, ne pune la dispozitie nenea vasilica grecu. performantele sunt modeste dar pentru inceput e suficient. plus ca, cu unele modificari (folosirea unui ADC extern, conectat paralel cu AVR) bada se poate extinde la peste 20 KHz.
http://www.serasidis.gr/circuits/AVR_oscil...scilloscope.htm
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-13382
20KHz mai bine folosesti placa de sunet cu o adaptare pentru tensiuni mai mari .
Daca vrei sa folosesti portu paralel poti sa faci unu destul de sinplu pana la 200KHz fara nici o problema .
Configuratia pentru PAL o am eu dar nu am avut timp sa o pun aici iar schema este de pe un disc original ce greseli are mai concret ca ma intereseaza si pe mine ,iar softu este unu singur pentru mai multe dispozitive mai exact pentru toate tipurile de osciloscoape ,generator de functii cu fereastra de editare a formei de unda etc.
Pretu pe care lam pus acolo este pentru osciloscopu gata facut nu a conponentelor .
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-13413
  • 6 years later...
Cine vrea satransforme receptorul Tv in osciloscop, fara sa desfaca nici macar capacul, poate incerca schema prezentata in Tehnium nr. 5/1984 de la pagina 12/13. Pentru simplitate am realizat un montaj care cuprinde intregul articol. Cine vrea sa vada un caz grosolan de plagiat (aproape 100 %) poate sa vada aceeasi schema rearanjata si semnata de un alt "autor" in Tehnium 5/6-90 la pagina 12
https://www.tehnium-azi.ro/forums/topic/202-osciloscop/#findComment-59082
