Pic16F 877A-I/L 25ron/buc 4x11
Pic16F 877A-I/P 20ron/buc 2x20
Pic16F 877 -04I/P 20ron/buc 2x20
Pic16F 877 -20I/P 20ron/buc 2x20
Pic16F 876 -04I/SO 15ron/buc 2x14 SMD
Pic16F 876 -20I/SO 15ron/buc 2x14 SMD
Pic16F 876 -20I/SP 15ron/buc 2x14
Pic16F 876 -04I/SP 15ron/buc 2x14
Pic16LF 874A-I/L 20ron/buc 4x11
Pic16LF 874A-I/P 20ron/buc 2x20
Pic16F 873A-I/SP 15ron/buc 2x14
Pic16LF 873A-I/SP 15ron/buc 2x14
Pic16F 873 -20I/SP 20ron/buc 2x14
Pic18F 458 -I/P 25ron/buc 2x20
Pic18LF 458 -I/P 25ron/buc 2x20
Pic18LF 448 -I/L 25ron/buc 4x11
Pic18LF 442 -I/L 25ron/buc 4x11
Pic18F 442 -I/P 20ron/buc 2x20
Pic16F 84A -20I/SO 15ron/buc 2x9 SMD
Pic16LF 84A -04I/P 12ron/buc 2x9
Pic16F 84 -04I/P 12ron/buc 2x9
Pic16F 83 -04I/P 12ron/buc 2x9
Pic16F 76 -I/SP 20ron/buc 2x14
Pic16F 74A -I/P 20ron/buc 2x20
Pic16F 72 -I/SP 10ron/buc 2x14
Pic16F 628 -20I/SP 20ron/buc 2x9
Pic16F 628 -04I/SP 20ron/buc 2x9
Pic18C 858 -I/L 40ron/buc 4x21
Pic18C 452J W 70ron/buc 2x20
HM2007 70ron/buc 2x24 1 buc
MCP41010 I/P 6,5ron/buc 2x4 2 buc
MCP41050 I/P 6,5ron/buc 2x4 6 buc
MCP3008 I/P 8ron/buc 2x8 3 buc
MCP42100 I/P 10ron/buc 2x8 2 buc
MCP42010 I/P 10ron/buc 2x8 2 buc
MCP42050 I/P 10ron/buc 2x8 2 buc
MCP3208 C I/P 2,5ron/buc 2x8 6 buc
MCP1541 I 7,5ron/buc 3 pini 2 buc
Procesor 933Mhz FSB133 256Cache 1,7V 1buc 50ron
Vu-metru+tahometru 1buc 30 ron, http://i27.tinypic.com/2e0mj4i.jpg, http://i32.tinypic.com/mutn6h.jpg
Handsfree SonyEricson 15 ron
http://i34.tinypic.com/2ug1mip.jpg
Condensator SPRAGUE 100000 microfarad/30V 2buc 50ron; http://i33.tinypic.com/1fxvg8.jpg
ScreenDuo+CD si manual=100 ron
http://www.engadget.com/2007/02/14/asus ... previewed/
http://www.sideshowdevices.com/screendu ... r-problems
http://www.everythingusb.com/asus_screenduo.html
http://www.mobilewhack.com/asus-screenduo/
http://gizmodo.com/gadgets/gadgets/asus ... 230719.php
MJE 15030 9buc 2ron/buc
MJE 15031 10buc 2.2ron/buc
19buc=35ron
LCD 4x20 cu Backlight DEM20486SYH-LY/V029 1buc 50ron, http://i37.tinypic.com/28ix7dg.jpg, http://i35.tinypic.com/659v2s.jpg
LCD 2x16 LM052L 2buc 20ron/buc, http://i38.tinypic.com/ev10tj.jpg (unul rezervat)
Pentium I 166Mhz 1buc/5ron
CPU Celeron 466 socket 370 2buc 20ron/buc
Pentium II 400Mhz Slot 1 2buc/25ron/buc
SVGA AGP INTEL 740 / 8Mb 1buc/10ron, http://i38.tinypic.com/24cwt91.jpg
SVGA AGP SIS 6326 / 8M 2buc 10ron/buc, http://i36.tinypic.com/2nkkxg8.jpg
SVGA AGP ATI 3D RANGE II C / 4M 1buc/7ron
SVGA AGP Cirrus Logic 5465 / 4M 1buc/7ron, http://i33.tinypic.com/2lj2ov8.jpg
SVGA AGP S3 Trio 3D / 4M 1buc/7ron, http://i36.tinypic.com/ajtiyd.jpg
SOUND YAMAHA 719E-S ISA 1buc 10ron/buc
Alimentator 100-240Vca /12Vcc/2A 1buc/30ron
AT89C2051-24PC 2buc 2ron/buc
S202SE1 2buc 15ron/buc
S202S02 1buc 15ronbuc
PCF80C552-5 16WP + soclu 2buc 5ron/buc
SAB80C535-N + soclu 1buc/5ron
ADUC834BS 1buc/25ron
ADC12062CIV + soclu 1buc/20ron
AD1848JP SoundPort + soclu 1buc/20ron
Diode D10N5+radiator propriu 22buc 2ron/buc, toate 35ron, http://i25.tinypic.com/10ok8xt.jpg, http://i26.tinypic.com/2eykm14.jpg
Potentiometre Bobinate
100 ohm/50W 1buc(corp ceramic) 10ron
56 ohm 5buc(corp ebonita) 1.5ron/buc
330 ohm 1buc(corp ebonita) 1.5ron/buc
5K 8buc(corp ebonita) poate si mai multi 1.5ron/buc
TRANSFORMATOR 220/110 Vca 100W 1buc 30ron+transport
256Mb/PC133 M-tec Dual Layer 2buc 40 ron/buc
256Mb/PC133 Teake-MS Dual Layer 1buc 40 ron/buc
256Mb/PC100 Nec Dual Layer 1 buc 40 ron/buc
128Mb/PC100 Infineon Dual Layer 1buc 20ron/buc
128Mb/PC100 Samsung Dual Layer 1buc 20ron/buc
64Mb/PC133 M-tec Single Layer 5buc 10 ron/buc
64Mb/PC100 M-tec Single Layer 2buc 8ron/buc
64Mb/PC100 Hyundai Single Layer 1buc 8ron/buc
32Mb/PC100 SpecTek Single Layer 9 buc 4ron/buc
32Mb/PC100 VM Single Layer 1 buc 4ron/buc
32Mb/PC100 NANYA Single Layer 1 buc 4ron/buc
32Mb/PC100 SIEMENS Single Layer 1 buc 4ron/buc
Switch 16 porturi 100 cu alimentare externa 50ron
LM3886T 4buc 22.5ron/buc+transport, http://i35.tinypic.com/a0jksk.jpg
4x10000 micro/63V 60ron, http://i25.tinypic.com/qralwo.jpg
24x6800 micro/63V Philips 10ron/buc, http://i26.tinypic.com/282q9s2.jpg
potentiometru multitur
2x10K 20ron/buc,
2x 5K 20ron/buc
4x 2K 20ron/buc, http://i32.tinypic.com/20a9tnc.jpg
2x 1K 20ron/buc, http://i30.tinypic.com/2n8wxvb.jpg
2x100 ohm 20ron/buc
ECL82 1buc 10ron
PL82 1buc 10ron
EF86 12buc 15ron/buc (toate 150ron cu transport inclus)
OC3/VR105 1buc 20ron
12AT7 1buc 15ron
kiru_tu
Editat de kiru_tu
https://www.tehnium-azi.ro/forums/topic/1981-mai-multe/
AC Power Adapter 20V/3A model LSE9802A2060 100ron
Este o singura bucata, nu este nou, a fost scos dintr-un proiect de laborator.
Dupa codul de pe regulator nu prea imi dau seama PAC 15 P 002081 intuiesc ca ar fi vorba de 20A dar nu garantez.
Poze reale: http://i35.tinypic.com/2r5dwra.jpg; http://i35.tinypic.com/33wtpmx.jpg; http://i34.tinypic.com/20fda1l.jpg
19buc=35ron
LCD 2x16 LM052L 1buc 20ron/buc, http://i40.tinypic.com/zu3194.jpg
SOUND ESS Solo-1 PCI 1buc 15 ron
SOUND ENSONIC ES1370 PCI 1 buc 15 ron
2x10K 20ron/buc,
2x 5K 20ron/buc
2x100 ohm 20ron/buc
ECL82 1buc 10ron
PL82 1buc 10ron
12AT7 1buc 15ron
kiru_tu
LATER EDIT : Va rog nu mai postati doua topicuri unul dupa altul , postati totul in unul sau folositi functia edit !
O zi buna !
Editat de B?RBOS RADU IOAN
https://www.tehnium-azi.ro/forums/topic/1981-mai-multe/#findComment-18769
  • 4 months later...
AMD
Xp 2000+
AXDA2000DUT3C = 50 Ron
Sempron 2200+
SDA2200DUT3D = 50 Ron
INTEL
Celeron 466 socket 370 15 Ron
PIII 933MHz/256/133/1,7V socket 370 = 35 Ron
PIII 733MHz/256/133/1.7V socket 370 = 30 Ron
PIV 1.8MHz//256/400/1.75V socket 478 = 60Ron
19buc=35ron
2x10K 20ron/buc,
2x 5K 20ron/buc
2x100 ohm 20ron/buc
ECL82 1buc 10ron
PL82 1buc 10ron
12AT7 1buc 15ron
kiru_tu
O zi buna !
https://www.tehnium-azi.ro/forums/topic/1981-mai-multe/#findComment-21490
  • 5 months later...
Memorii
2x256 Mb/PC133 Double Side chipuri takeMS (MS64S32220U-7.5 ) 2buc 2x35ron
2x256 Mb/PC133 Double Side chipuri M.tec (S/N:120MDG10626030107; S/N:147M51045071698) 2buc 2x35ron
1x256 Mb/PC100 Double Side chipuri NEC 1buc 1x30ron
1x256 Mb/PC100 Double Side chipuri VDATA 1buc 1x30ron
4x128 Mb/PC133 Single Side chipuri M.tec (S/N:047MDGH06960421; S/N:140M51037852795; S/N:140M51037852796; S/N:140M51037852797) 4buc 4x15ron
3x128Mb/PC133 Single Side chipuri PQI 3buc 3x15ron
1x128Mb/PC133 Double Side chipuri PQI 1buc 1x15ron
1x128Mb/PC133 Double Side chipuri HYUNDA 1buc 1x15ron
2x128Mb/PC100 Single Side chipuri VDATA 2buc 2x12.5ron
2x128Mb/PC100 Double Side chipuri INFINEON 2buc 2x12.5ron
1x128Mb/PC100 Double Side chipuri IProc 1buc 1x12.5ron
1x128Mb/PC100 Double Side chipuri SAMSUNG 1buc 1x12.5ron
2x256Mb DDR2/533 P/N:SY-DDR2-256M533 (S/N:7128E02345; S/N:7128E02346) 2buc 2x20ron
1x256Mb DDR1/PC2100 SYCRON 1buc 1x15ron
1x256Mb DDR1/PC266 TRANSCEND 1buc 1x15ron
PROCESOARE
Pentium 4 Socket 775 D805 2.66MHz/533/2M cache (SL8ZH) 1buc 1x120ron
Pentium 4 Socket 478 1.8Mhz/256/400/1.75V (SL5VJ) 2buc 2x45ron
CELERON Socket 478 1.7Mhz/128/400/1.75V (SL68C) 1buc 1x35ron
Pentium 3 Socket 370 933Mhz/256/133/1.7V (3109A140-0588 SL4C9) 1buc 1x35ron
Pentium 3 Socket 370 933Mhz/256/133/1.7V (7111A185-0643 SL4C9) 1buc 1x35ron
Pentium 3 Socket 370 933Mhz/256/133/1.7V (3109A140-01892 SL4C9)1buc 1x35ron
Pentium 3 Socket 370 800Mhz/256/133/1.75V (3133A151-0430 SL52P) 1buc 1x30ron
Pentium 3 Socket 370 800Mhz/256/133/1.75V (L122A565-0329 SL52P) 1buc 1x30ron
AMD DURON Socket A 850Mhz1buc 1x30ron
AMD Barton Socket A 3000+Mhz 1buc 1x120ron
AMD Athlon Socket A 2000+Mhz (AXDA2000DUT3C)1buc 1x45ron
AMD Sempron Socket A 2200+Mhz (SDA 2200DUT3D)1buc 1x50ron
24x6800 micro/63V Philips 7ron/buc, http://i26.tinypic.com/282q9s2.jpg
2x10K 20ron/buc,
2x 5K 20ron/buc
2x100 ohm 20ron/buc
ECL82 1buc 10ron
PL82 1buc 10ron
12AT7 1buc 15ron
19buc=35ron
https://www.tehnium-azi.ro/forums/topic/1981-mai-multe/#findComment-25240
Placa de baza Asus P4C800 deluxe + Procesor Intel Socket Pentium IV 478/3.2GHz/800/1M cache + cooler 200 ron pret fix
eventual 2x512Mb/DDR1/400 PQI 80ron
Memorii
Memorii SD
1Gb A-data 2buc 2x17ron
1Gb Transcend 1buc 1x17ron
PROCESOARE
Intel core2duo E6600 LGA775/2.4GHz/4M/1066 65nm SL9ZL 200ron pret fix
ADAPTOR PCI to ATA 1x25ron
HighPoint Rocket 133
manual si driver
http://www.highpoint-tech.com/USA/r133.htm
ADAPTOR PCI to 4 USB 2.0 1x20ron
PCI-VIA6202-1
Xp il recunoaste
Radiatoare
Radiator culoare neagra lungime 51cm latime 8.8cm inaltime aripioare 3.5 gauri practicate pentru 11 tranzistoare capsula TO3 70ron
http://i49.tinypic.com/qrcjt1.jpg
http://i50.tinypic.com/33216jr.jpg
Surse Comutatie direct din 220Vca
Sursa 1 = 20ron
5V/3A : 12V/2A : -12V/0.3A
Lungime12.7cm latime7.6cm inaltime3.3cm
http://i46.tinypic.com/168x3qu.jpg
http://i45.tinypic.com/m9x3xc.jpg
Sursa 2 = 10ron
10.84V/????A
Lungime13cm latime7cm inaltime3cm
http://i50.tinypic.com/33x905s.jpg
http://i49.tinypic.com/rh7txt.jpg
Motoare
Motor cu reductor 2buc 2x40ron
http://i45.tinypic.com/157zrd5.jpg
Lungime totala motor+reductor+ax 72mm
Lungime motor 39mm
Diametru motor 27.5mm
Lungime Reductor 23mm
Diametru Reductor 33mm
Lungime Ax 10mm
Diametru Ax 5mm
Motor cu reductor 1buc 1x50ron
http://i47.tinypic.com/1hdvli.jpg
Lungime totala motor+reductor+ax 51mm
Lungime motor 24mm
Diametru motor 16mm
Lungime Reductor 18.5mm
Diametru Reductor 15mm
Lungime Ax 8mm
Diametru Ax 3mm
Pachetul mai are si un microfon stereo(nu apare in imagini)
Cu fixare pozitionare pe un LCD TFT
http://i47.tinypic.com/ivwqad.jpg
http://i50.tinypic.com/2p4qu.jpg
19buc=35ron
ECL82 1buc 10ron
PL82 1buc 10ron
12AT7 1buc 15ron
Condensatori
18x6800 micro/63V Philips 7ron/buc, http://i26.tinypic.com/282q9s2.jpg
Potentiometru multitur
2x10K 20ron/buc,
2x 5K 20ron/buc
2x100 ohm 20ron/buc
Diode D10N5(10A,500V)+radiator propriu 22buc 2ron/buc, toate 35ron,
http://i49.tinypic.com/34pcghs.jpg
100 ohm/50W 2buc(corp ceramic) 10ron
TRANSFORMATOARE
Transformator 220/110 Vca 100W 1buc 30ron
Transformator 220Vca/21Vca 2A 2buc 20ron/buc
Transformator 220Vca/18Vca 25ron
Sarma din secundar aproximativ 1.5/1.8mmm
Lungime 9.5cm/Latime 9.5cm/Inaltime 11.5cm
http://i48.tinypic.com/23mrl2x.jpg
http://i45.tinypic.com/12228ub.jpg
Transformator
220Vca/2x20Vca/1x19Vca/1x12Vca/1x37Vca 15ron
Curenti mici probabil pana in 500-700mA
Inaltime 8.5cm/Latime 7cm/Lungime 8.5cm
http://i46.tinypic.com/vmsjv4.jpg
http://i46.tinypic.com/2i07t37.jpg
http://i48.tinypic.com/2rwsxlj.jpg
Transformator
220Vca/2x20Vca100mA/2x16Vca/500-600mA 10ron
Inaltime 9.5cm/Latime 6cm/Lungime 6cm
http://i45.tinypic.com/2hqatjr.jpg
http://i50.tinypic.com/1pyvf4.jpg
YD kiru_tu
Editat de kiru_tu
https://www.tehnium-azi.ro/forums/topic/1981-mai-multe/#findComment-25651
