Niste manuale de utilizare si documentatii cred ca ar fi potrivite cu cerinta expusa!
http://www.cooperhandtools.com/europe/spar...3000V_GB2.3.pdf
http://home.comet.bg/datasheets/JBC/2700200.pdf
http://www.inter-tec.com/shop/images/brochure_(lo-res).pdf
http://www.irf.com/technical-info/appnotes/an-1011.pdf
http://www.howardelectronics.com/download/Manuals/ar5800.pdf
http://www.teknetelectronics.com/DataSheet...BWAHLST2200.pdf
Un PDF mult mai aproape de problema:
Soldering_Station_Specs.pdf
Si un PDF despre cum lipim sau utilizam statiile de lipit (nu neaparat si cu aer cald).
curious_inventor___how_soldering.pdf
Numai bine.
https://www.tehnium-azi.ro/forums/topic/1581-statie-de-lipit-cu-aer-cald/#findComment-15248
Am gasit deocamdata doar niste specificatii tehnice succinte ale unor aparate :Technical Specifications:
Dimensions
L x W x H (inches): 10.75 x 9.25 x 4.02
Weight: Approximately 14.8 lbs.
Power supply voltage: 120 VAC, 60 Hz
Power consumption: 400 Watts
EOS / ESD Properties: All Tool Handles, Cordsets and Air Flow are Static Free
Fuse: 4 Amp
Temperature control range: Variable in (1) degree increments from 150?F - 999?F Controllable temperature range is tool-dependent
Temperature accuracy: ? 17?F (Average tip temperature can be offset ? 9?F at idle with no load)
Temperature stability: ? 9?F
Hot Air / Vacuum Pump
(duty cycle: 30 seconds on,
30 seconds off): Max. vacuum 0.7 bar Max. delivery rate 18 l/min Hot air max. 15 l/min
Vacuum Pick-up Pump
(duty cycle: 60 seconds on,
30 seconds off): Max. vacuum 0.5 bar Max. delivery rate 1.7 l/min
sursa:
http://www.lashen.com/vendors/CooperTools/...er_high_end.asp
P.S.
In timp ce postam am mai gasit un link cu un minim de documentatie http://www.cooperhandtools.com/europe/spar...3000V_GB2.3.pdf
https://www.tehnium-azi.ro/forums/topic/1581-statie-de-lipit-cu-aer-cald/#findComment-15249
Despre aceasta este vorba Nu este mai slab dar este destul de slab
http://www.gsmaccesorii.ro/aparatura-servi...ukey-852d---692
Editat de ardeleanu bogdan
https://www.tehnium-azi.ro/forums/topic/1581-statie-de-lipit-cu-aer-cald/#findComment-15257
