Scheme de amplificatoare audio
itzi las eu o schema simpla ................cu un tda8560Q............personal am realizat acest amplif shi vreau sa spun ca merge foarte bn.......iar alimentarea potzi sa o iei dintr-o sursa de Pc.........schema o gasesti la pagina 10 a pdf-ului
TDA8560Q.pdf
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/6/#findComment-21609
Un amplificator pe care le-am construit si sunt foarte multumit de el.Finalele se poate schimba cu MJ15003-MJ15004 si prefinalele cu bd237-bd238.Suporta lejer +-45v.Este un amplificator simplu de tranzistoare.
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/6/#findComment-22678
Do It Yourself Projects = Amplificatoare Audio:
# 10 Watt Audio Amplifier
# 10 watt audio power amplifier using discrete transistors (includes PCB layout)
# 100W Guitar Amplifier
# 100W RMS Amplifier
# 13.5 Watt Power Amplifier using a TL081 opamp and TIP125 / TIP120 power transistors
# 150W audio amplifier that's cheap to build using TIP142 / TIP147 Darlington power transistors
# 16 Watt amplifier
# 20 Watt / Channel Stereo Power Amplifier
# 20 Watt Audio Power Amplifier
# 20 Watt Class-A Power Amplifier
# 22 Watt Audio Amplifier
# 22 Watt Stereo Amplifier using TDA1554
# 25 Watt MOSFET Audio Amplifier using IRF532 / IRF9532 hexfet transistors for output stage
# 10W Audio Amplifier
# 2W Audio Amplifier using BD139 and BD140 transistors
# 300W Subwoofer Power Amplifier
# 4 channel power amplifier with bi-amping and bridging options
# 50 Watt Amplifier
# 50W audio power amplifier
# 8 Watt amplifier
# 8 watt audio amp
# Ampliefied speaker, built for MP3 player but can be used with other headphone only devices (PDF)
# Build a good Audio Buffer Amplifier
# Class-A/AB Amplifier delivering 100W into a 4 ohm load
# Class-C power amplifier
# How build CMoy pocket headphone amplifier
# Compact 50W Integrated Amplifier with Meier Headphone Section
# Death of Zen (DoZ) - A New Class-A Power Amp
# DPA 220 amplifier schematic
# DPA 440 amplifier schematic
# DPA 880 amplifier schematic
# El-Cheapo - A Really Simple Power Amplifier
# Five Tube Stereo Amplifier
# Hammonator Organ to Guitar Amp Conversion (tube amplifier)
# Headphone amplifier based on 12AX7 tubes
# LM380 2.5 watt audio amplifier circuit
# Low Power Audio Amp Experiments
# Low power audio amplifier using BC109C along with BD679 and BD680 Darlington pairs
# Mini bench amplifier (LM386)
# Miniature audio amplifier
# Mini-MosFet Audio Amplifier
# More Discrete BJT, Low Power AF Amp Experiments
# Potpourri of Transistor Audio Amplifier Circuits
# Quadraphonic Amplifier based on pair of LM1877 devices
# Ruby is an "enhanced" version of the Little Gem battery-powered amplifier (LM386 based design)
# Selection of Integrated Circuit Audio Amplifiers
# Simple class-D amplifier based on 555 pulse width modulator
# Single Chip 50 Watt / 8 Ohm Power Amplifier - LM3876
# Spatial Distortion Reduction Headphone Amp
# Speech Amplifier Box
# Stereo audio amplifier based on TDA2822M
# Super linear Headphone amplifier
# TDA2030 8 Watt amplifier
# Tube amplifier
# Two 9v battery-powered amps based on the LM386. Schematic and PCB/perfboard layouts.
# Two Transistors Audio Amplifier
# Voice Amplifier
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/6/#findComment-26758
