Scheme de amplificatoare audio
Amplificator audio cu MOSFET 300W in 4 Ohmi (tensiunea tipica de alimentare intre +/-50Vcc si +/-60Vcc):
amplficator_audio_cu_MOSFET.pdf
Observatie importanta: Daca doriti sa utilizati montajul alimentat la peste +/-60Vcc atunci inlocuiti BC640 cu 2N5401 sau 2SA1085E si BC639 cu MPSA42 sau MJE340.
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/2/#findComment-3212
Aici aveti schema amplificatorului postat pentru discutii de catre mine UN AMPLIFICATOR SIMPLU !
SCHEMA !
This project was a sort of challenge: designing an audio amplifier capable of delivering a decent output power with a minimum parts count, without sacrificing quality.
The Power Amplifier section employs only three transistors and a handful of resistors and capacitors in a shunt feedback configuration but can deliver more than 18W into 8 Ohm with <0.08% THD @ 1KHz at the onset of clipping (0.04% @ 1W - 1KHz and 0.02% @ 1W - 10KHz) and up to 30W into a 4 Ohm load.
To obtain such a performance and to ensure overall stability of this very simple circuitry, a suitable regulated dc power supply is mandatory. This is not a snag because it also helps in keeping noise and hum of the preamp to very low levels and guarantees a predictable output power into different load impedances. Finally, as the amplifier requires only a single rail supply, a very good dc voltage regulator capable of supplying more than 2 Amps @ 40V can be implemented with a few parts also.
Power Amplifier Parts:
R1_______________2K2 1/4W Resistor
R2______________27K 1/4W Resistor
R3,R4____________2K2 1/2W Trimmers Cermet or Carbon (or 2K)
R5_____________100R 1/4W Resistor
R6_______________1K 1/4W Resistor
R7,R8__________330R 1/4W Resistors
C1______________22µF 25V Electrolytic Capacitor
C2______________47pF 63V Polystyrene or Ceramic Capacitor
C3,C4__________100µF 50V Electrolytic Capacitors
C5____________2200µF 50V Electrolytic Capacitor
Q1____________BC550C 45V 100mA Low noise High gain NPN Transistor
Q2___________IRF530 100V 14A N-Channel Hexfet Transistor (or MTP12N10)
Q3__________IRF9530 100V 12A P-Channel Hexfet Transistor (or MTP12P10)
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/2/#findComment-4009
1. Un amplificator audio de calitate pe care il recomand tuturor celor daca doresc sa-si contruiasca acasa un sistem audio Hi-Fi de exceptie (137W in 4Ohmi, THD 0,1%):
Amplificator_audio_HI_FI_137W_4Ohmi_cu_MOSFET.rar
2. Un amplificator audio simplu numai cu trei MOSFET-uri, 10W in 4 Ohmi:
Amplificator_audio_10W_cu_MOSFET.rar
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/2/#findComment-4069
Amplificatoare audio Hi-Fi in clasa A:
1. Aleph 1.2:
http://www.kk-pcb.com/aleph-12.html
2. Aleph 2:
http://www.kk-pcb.com/aleph-2.html
3. Aleph 3:
http://www.kk-pcb.com/aleph-3.html
4. Aleph 4:
http://www.kk-pcb.com/aleph-4.html
5. Aleph 5:
http://www.kk-pcb.com/aleph-5.html
6. Aleph M:
http://www.kk-pcb.com/mini-a.html
7. Aleph X:
http://www.kk-pcb.com/alephx.html
Amplificatoare audio ZEN Hi-Fi in clasa A:
1.ZEN-X:
http://www.kk-pcb.com/zen-x.html
2.ZEN-XA:
http://www.kk-pcb.com/zen-xa.html
ENJOY.
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/2/#findComment-4174
  • 4 weeks later...
Postez si aici o schema simpla si performanta de amplificator audio (LM-ul se poate inlocui cu un AO uzual cu circuitele de alimentare cu dioda Zener atasate). In anumite siutatii este necesar si un preamplificator audio.
https://www.tehnium-azi.ro/forums/topic/128-scheme-de-amplificatoare-audio/page/2/#findComment-5750
