Poză
Scheme de amplificatoare audio
* * * * * 7 voturi
173 răspunsuri în acest subiect
#91
prog
prog
    Utilizator Tehnician
  • Members
  • 299 postari
Do It Yourself Projects = Amplificatoare Audio:
# 10 Watt Audio Amplifier
# 10 watt audio power amplifier using discrete transistors (includes PCB layout)
# 100W Guitar Amplifier
# 100W RMS Amplifier
# 13.5 Watt Power Amplifier using a TL081 opamp and TIP125 / TIP120 power transistors
# 150W audio amplifier that's cheap to build using TIP142 / TIP147 Darlington power transistors
# 16 Watt amplifier
# 20 Watt / Channel Stereo Power Amplifier
# 20 Watt Audio Power Amplifier
# 20 Watt Class-A Power Amplifier
# 22 Watt Audio Amplifier
# 22 Watt Stereo Amplifier using TDA1554
# 25 Watt MOSFET Audio Amplifier using IRF532 / IRF9532 hexfet transistors for output stage
# 10W Audio Amplifier
# 2W Audio Amplifier using BD139 and BD140 transistors
# 300W Subwoofer Power Amplifier
# 4 channel power amplifier with bi-amping and bridging options
# 50 Watt Amplifier
# 50W audio power amplifier
# 8 Watt amplifier
# 8 watt audio amp
# Ampliefied speaker, built for MP3 player but can be used with other headphone only devices (PDF)
# Build a good Audio Buffer Amplifier
# Class-A/AB Amplifier delivering 100W into a 4 ohm load
# Class-C power amplifier
# How build CMoy pocket headphone amplifier
# Compact 50W Integrated Amplifier with Meier Headphone Section
# Death of Zen (DoZ) - A New Class-A Power Amp
# DPA 220 amplifier schematic
# DPA 440 amplifier schematic
# DPA 880 amplifier schematic
# El-Cheapo - A Really Simple Power Amplifier
# Five Tube Stereo Amplifier
# Hammonator Organ to Guitar Amp Conversion (tube amplifier)
# Headphone amplifier based on 12AX7 tubes
# LM380 2.5 watt audio amplifier circuit
# Low Power Audio Amp Experiments
# Low power audio amplifier using BC109C along with BD679 and BD680 Darlington pairs
# Mini bench amplifier (LM386)
# Miniature audio amplifier
# Mini-MosFet Audio Amplifier
# More Discrete BJT, Low Power AF Amp Experiments
# Potpourri of Transistor Audio Amplifier Circuits
# Quadraphonic Amplifier based on pair of LM1877 devices
# Ruby is an "enhanced" version of the Little Gem battery-powered amplifier (LM386 based design)
# Selection of Integrated Circuit Audio Amplifiers
# Simple class-D amplifier based on 555 pulse width modulator
# Single Chip 50 Watt / 8 Ohm Power Amplifier - LM3876
# Spatial Distortion Reduction Headphone Amp
# Speech Amplifier Box
# Stereo audio amplifier based on TDA2822M
# Super linear Headphone amplifier
# TDA2030 8 Watt amplifier
# Tube amplifier
# Two 9v battery-powered amps based on the LM386. Schematic and PCB/perfboard layouts.
# Two Transistors Audio Amplifier
# Voice Amplifier
#92
alessia70578
alessia70578
    Membru
  • Members
  • 16 postari
DonPetru, postez aici, pe topicul initiat de dumneavoastra, o schema de amplificator JF, publicata de un site in limba ceha. Datorita faptului ca montajul este explicat in amanunt, cred ca va fi considerata interesanta.
Iata adresa: http://www.lf-pro.ne...e/symasym5.html
Editare Administrator - Performantele schemei de amplificator de pe site-ul ceh inditulata Symasym5 sunt urmatoarele (Ualimentare=+/-36Vcc):
- frecventa test sinus: 50Hz; Vin=493mVef, Z=4Ohm >>> Pz=100,03W; THD=0,022%, Curentul prin finali aprox. 2,226Aef;
- frecventa test sinus: 1kHz; Vin=493mVef, Z=4Ohm >>> Pz=100,11W; THD=0,023%, Curentul prin finali aprox. 2,227Aef;
- frecventa test sinus: 15kHz; Vin=493mVef, Z=4Ohm >>> Pz=99,24W; THD=0,4%, Curentul prin finali aprox. 2,588Aef.
#93
donpetru
donpetru
    Administrators
  • Root Admin
  • 6.613 postari
  • Resedinta:Galati
Fișier atașat  100W_2SC2922_2SA1216.jpg   27,36K   148 descărcări
Fișier atașat  Quad_405_mod.jpg   190,49K   150 descărcări
#94
donpetru
donpetru
    Administrators
  • Root Admin
  • 6.613 postari
  • Resedinta:Galati
Fișier atașat  AX14 APEX Amplifier.jpg   426,8K   326 descărcări Fișier atașat  APEX B50.jpg   203,09K   379 descărcări Fișier atașat  B200 Apex with TDA7294 brigde.jpg   291,38K   297 descărcări Fișier atașat  N10 APEX Mosfet.jpg   343,59K   262 descărcări
Fișier atașat  PSU Apex Amplifiers.jpg   394,04K   254 descărcări Fișier atașat  PCB Apex TDA7294 in punte.jpg   209,28K   231 descărcări Fișier atașat  PCB PSU Apex Amplifiers.jpg   762,93K   163 descărcări
numai bine
#95
cristi_74
cristi_74
    Premium User
  • Tehnium Azi
  • 337 postari
  • Resedinta:Binis C-S
PA300 bipolari.
  • Fișier atașat  PA300.pdf   846,93K   252 descărcări
#96
Guest_alex mm_*
  • Guests
O schema mult discutata pe Diy Audio .....
Cablaj imprimat proiectat de mine ...executat in Hong Kong
Si un mic progres in echiparea placii..... :unknow:
#97
doktort34
doktort34
    Membru
  • Members
  • 23 postari
  • Resedinta:iasi
300wFișier atașat  amp146-5.png   53,05K   433 descărcări
Editat de doktort34, 12 ianuarie 2011 - 01:40 .
#98
cristi_74
cristi_74
    Premium User
  • Tehnium Azi
  • 337 postari
Quad-405 R.Ludwig+PCB 2 finali....4 finali
Quad_405 R.Ludwig+pcb v5.0_4 finali.
Quad 405 R.Ludwig modificat+pcb alex mm_4 finali
#99
donpetru
donpetru
    Administrators
  • Root Admin
  • 6.613 postari
  • Resedinta:Galati
Fișier atașat  audio amp 100.png   66,46K   203 descărcări Fișier atașat  audio amp 300.png   71,64K   204 descărcări
#100
jack_roby2008
jack_roby2008
  • Members
  • 197 postari
  • Resedinta:Craiova
Atasez si eu o schema
#101
donpetru
donpetru
    Administrators
  • Root Admin
  • 6.613 postari
  • Resedinta:Galati
Fișier atașat  ZECK MOSFET-BJT classH.JPG   174,8K   120 descărcări Fișier atașat  30W MOSFET decembrie 1980.gif   50K   143 descărcări Fișier atașat  200W MOSFET Iulie 1984.gif   81,75K   149 descărcări
Fișier atașat  100W MOSFET august 1982.gif   77,43K   176 descărcări Fișier atașat  500W_MJL21193_21194.jpg   153,69K   155 descărcări
#102
leo_electro
leo_electro
    Members
  • Tehnium Azi
  • 409 postari
  • Resedinta:Olanda
Amplificator audio:
#103
donpetru
donpetru
    Administrators
  • Root Admin
  • 6.613 postari
  • Resedinta:Galati
Un amplificator audio in clasa D:
Fișier atașat  Amplificator audio de 170W in clasa D.gif   53,65K   94 descărcări
#104
iulian_zamfir
iulian_zamfir
  • Members
  • 134 postari
  • Resedinta:Vaslui
Doua scheme de amplificatoare:
1. Titan 2000:
Fișier atașat  TITAN 2000.jpg   109K   227 descărcări Fișier atașat  2000w_power_amplifier.gif   278,56K   323 descărcăriFișier atașat  cablaj TITAN 2000.jpg   281,92K   315 descărcări
2. Amplificator audio MOSFET PHILIPS:
Fișier atașat  200w-philips-mosfet-amplifier.jpg   93,16K   259 descărcări
Editat de iuly2010, 20 mai 2011 - 09:23 .
#105
Letcon
Letcon
    Premium User
  • Tehnium Azi
  • 343 postari
  • Resedinta:Blaj-Alba
Aceeasi schema dar cu alti finali IRF540+cablaj:
Fișier atașat  ClassD_Circuit jpg.jpg   125,14K   348 descărcări
Fișier atașat  ClassD_PCB jpg.jpg   292,51K   312 descărcări
Interesanta schema si nu foarte complexa,as fi curios cum merge.
